Dome lights (wiring diagram help?)
TinBucket
So I've searched a bit and it sounds like most people who've had dome failures:
the bulb was burnt
the fuse was burnt
the switches stuck
So in my case the bulbs both work when switched to ON (fuse and bulb)
and my door-open light turns on/dings (switch)
am I missing something to check?
I have a couple other electrical issues I'd like to investigate, so if someone has ALL the diagrams I'd be forever grateful.
the bulb was burnt
the fuse was burnt
the switches stuck
Those who want wiring diagrams need to specify the year of their vehicle or have it in their sig, like most of us do. Toyota changed wire colors constantly over the years.
Have you tried all four doors to see if they come on? Are you sure you are in DOOR position on the switch? (Center is OFF; Door Control is all the way to the rear.)
MMJR_T4R
