Donahoe Questions
Chalk Outline
I just had a set of Donahoe c/os installed. The rear shocks should be in this week. I do have a question though. My intent was to stay pretty close to stock lift for the time being but even with the collars all the way to top I'm getting a bit over 1.5 inches of lift in the front. With the stock rear springs this is taking me to level, maybe even a bit nose high ... not what I had in mind. Donahoe says these are adjustable from 0 to 3" but mine look like there is no zero, just 1.5" on up. I guess my questions are does anyone have these installed to provide less than 1.5" of lift in the front and is there any trick to it? If you've had these a while have they settled in a half inch or so or do they pretty much hold their original set? On the plus side, the truck handles great and the front suspension doesn't bottom out on speed bumps anymore. :)
I do not have these but I would think that there will be some settling as time passes. When I did my spacer lift I lost at least a half inch after it settled.
EnviroHokie
