Door Handle Fail After Actuator Motor Replacement
MCinKC
Replaced the actuator motor on front driver’s side door of my 2017 last night. All went well with the motor switch thanks to a post from this forum. Key fob now locks and unlocks all doors.
However, after reinstall the outside door handle does not work! Did I knock something loose? Seems like it should be an easy fix, I just haven’t seen any info on this issue.
Thanks in advance!
Totally normal. You are on the right track. If you got all connections right and battery connected close all doors. Use your (physical) key to close and then open all doors (2 turns to open all) and you will be all set. Unless you left door handle cable disconnected when you installed door panel back. G.L.
