Door locks worn out... help?!
fo' runnin'
I guess all of my door locks are just totally worn out... rear hatch used to work if you wiggled the key in it enough, now nothing. Passenger door has never worked for me, and the driver door has always worked, but only with a generous amount of key wiggling and now it's getting to where it will only work half the time with a TON of key wiggling... and even the ignition is getting difficult to turn over sometimes now... How do you go about replacing all of the locks and ignition? Is there a full kit somewhere so that they all match and use the same key?
Can you try a different key? Maybe just the key is worn?
I've had duplicates made recently and they make it even harder to get it unlocked... :/
I see that RockAuto and Ebay both have a lock cylinder pair, but neither offer anything for the rear hatch and neither offer an ignition cylinder to match the doors... I really don't want to have to use 2 keys...
AndiGarage
