Door panel arm rest crunchy noise
Toyotas trim panels are some of the easiest to get off. I’d just pull it and see what’s happening in there.
Mine did that when it was new in 2019. I slid a little lithium grease down between the armrest and door panel. Hasn't made any noise since.
The top of the armrest is just a hair too long, so it bows up a little such that when you push down on it there is a little bit of vertical travel and the two materials rubbing up against each other make noise.
goddesszilla
