Downey Springs?
atx2ndgen
I have seen several threads that say Downey springs will correct the rear end sag on a 2nd gen t4r...sounds good to me!
The problem is I can't figure out where to buy them?!?!? Does anyone know where I can get them? :shrug:
+1 need to also know
Rear end sag is due to worn out springs, so any new spring will return it to stock height, or higher if the new springs are lift springs.
As for Downey, they are out of business.
Old Man Emu is a better choice, their suspension systems will make a vehicle ride and handle better than new.
Link? Should I replace the shocks if I do the springs?
FYI:I just replaced the front shocks the other week and it was real easy:frog:
If you replace the springs with springs that are meant to return it to stock height, your stock shocks will work (if they aren't worn out too).
If you replace the springs with springs that are meant to lift the height over stock, you will need longer shocks.
