Drilling holes through roof...
A friend of mine did the NMO in my roof for me. It was kind of scary watching him grab hold of the liner a yank it down after removing a few parts. Total time was probably 30 minutes but he wires emergency vehicles for a living.
Your friend is a ways away. Actually I am meeting up with some Colorado people in San Antonio, hence my recent flurry of activity.
I think for the CB, I will go magnet mount. For the ham radio, I really want a roof mount.
I found a local radio club that has a list of "resources". On that list were a couple locals who were listed as doing mobile installs. A person doing mobile installs has probably gone into some liners. I did see a YT video of a guy accessing the A pillar and the panel running above the front door, but he didn't show getting the liner loosened and putting it back.
Another question. The ideal situation would be a base-loaded antenna, center roof. What if that is by a rail on the rack. What distance should the antenna be from a rack rail and other antennas?
I'm far from expert but my local ham shop owner has multiple antenna mounted to his roof rack. I was surprised but he says they work great, fold down when not in use and easy to install. Maybe something to look in to.
Personally I went to a handheld ham since I hardly ever use it.
One note: If you go with a NMO in the roof remember it's there when you pull in to a garage. Those mounts are stronger than our roof! Yeah, don't ask!
Solid roof mounting is definitely the best way to go for any ham radio install. It gives you the best, most solid grounding.
Look for NMO mounts that require only a 3/8" hole - a bit easier to drill than a 3/4" hole. With that option, you do need to remove the entire headliner, which is a pain. All of the interior panels need to come out, then the headliner slides out of the back in one piece. There's a nice writeup someone did on this side about removing it when he installed a stereo system. The problem with having a sunroof is the limited availability of space. Reference the image I posted earlier - that's the closest forward I could mount the antenna and still leave room for the sunroof to slide back. I used thicker, low loss coax to feed that antenna since it's a 800MHz scanner antenna, but it wasn't hard to route it to the side and down the B pillar. If you have the time to do all of this, it's definitely worth it. It made a HUGE difference in the received signals.
I drilled holes through my 2nd gens roof to mount a roof rack on. Used rivets and put a silicone sealant over it and never had any problems. I even had one hole that was mis-drilled. So I filled it with the silicone sealant, it was perfect. I was nervous.... but it turned out just fine.
I am about to drill into mine for a rear deflector. I am curious specifically about the silicone placement. Do you drill hole, add silicone, then rivet, then screw? Or some other order.
Has anybody tried marine grade silicone sealant?
I realize this is an old thread but in case someone comes here and sees it i am going to chime in.
The above comment about marine grade silicone was going to be my recommendation.
3m 5200 will seal it.. It can seal a leak while submerged in water. Beware it IS permanent!
3m 4200 will seal it too. Very well. It is not permanent and cab be removed (with a lot of elbow grease) if necessary.
I have used both for transom bungs and other marine applications. If it were me I'd use 4200 for this.
are not silicone
agree with above post. Keep in mind those are more than plain silicone . Actually polyurethane and yes 5200 is permanent.
NVBASSJUNKIE
