Drive belts DIY?
Spaceman33
Is there a DIY out there for replacing the drive belts?
From initial glance, it looks like it is done best from the bottom.
I assume the alternator must be loosened to get that belt off.
Do the others have a tensioner?
How hard of a job is it?
What does the Stealer charge?
All belts will have the tensioner, if you have ever done belts before it is pretty straight forward and takes about 15-20 minutes with a beer. A/C tensioner is done most easily from under the truck with the removal of the front skid.
A quick Google will land ya on yotatech.com with a pretty good write up.
yotatech
Also always check out the 3rd Gen Fact/Tuts Page, if you haven't given it a good creeping then you need to.
Always have faith in yourself, you can ALWAYS learn to do things on your truck and save some green backs.. oh and here is a llama :llama:
GOOD LUCK!
Job is super easy, hardest part for me was doing the alternator adjustment. I had to have my gf tighten down the bolt while i kept the alternator tensioned.
Have fun
Have fun
To elaborate to OP: Yes, the other two belts (Power steering and air conditioning) have tensioners that when tightening the bolt, tension is increased on the drive belts. But the alternator is on a rail, and must be held taut to prevent slack, prior to final tightening.
Just what the doctor ordered.
I've done belts on Toyota's before. The DIY is pretty much the same.
Any opinion on OEM vs Autozone?
Thanks again
yotatech
GOOD LUCK!
Knocked this out this morning. Other than Autozone giving me one wrong belt, job was pretty easy. The DIY was great.
Seems like Advance gave me one wrong belt too. I can't remember which one it was. Whichever one it was, I had to get one about a half inch or so longer.
As a word of caution!!!
Do not brake off the nipple on the radiator cap. The hose that attacked on it and runs to the tank. I broke mine while I was doing my belts.
It was ether jb weld or get a new radiator. Jb weld has held this far. Knock on wood.
Alternator belt was the wrong one.
Luckily that's the easiest from the top and last to go on.
Now to figure out my oil leak.:yield:
BillM777
