Drive/Prop Shaft Grease Brands
I use the same grease on everything, just like the dealer does. Trust me, they are not using 2 different kinds of grease if they're even greasing it at all. I can tell you that both my 2016 Tacoma and 2016 4RUnner were not greased before I bought them brand new. All zerks were clean as a whistle and bone dry right off the lot. This is what I used, mostly because it's a good quality grease and I already had it on hand. When this runs out, i'll likely use the Mobil 1 equivalent.
https://www.ebay.com/itm/Multipurpo...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Since there's a mix of sliding joints (slip yoke) and needle roller bearings, the best type of grease to use if you want to avoid using two greases as per the manual is to use something rated GC-LB for chassis and bearing service. Almost all modern greases meet this spec. My preference is Mystik JT-6 high temp as it's known to be a very high quality grease with excellent properties.
