Drive shaft noise or U joint noise (LEXUS 4/06 TSB page 18) aka Driveshaft thump/bump
same here
I have not yet. I just attributed it to the way it was. Sometimes it does it worse than others, and if I ask the dealer about it during the test drive it would not do it.
My manufacture date is 09/02. Any others with this problem around the same time?
My runner has been doing the same thing and I can't figure it out...I just replaced my tranny mount thinking it was the problem and no luck...that was a waste of $100. I took it to a Toyota certified mechanic the other day and it never did it once during out test drive, like the dam runner knew the mechanic was on board, lol...... Well I asked him if he has heard about that problem at the dealership he worked at and he said no. Has anybody figured it out yet???? My buddy has a 97 2wd Runner and it does the same exact thing, WTH. Mine is a 98 4X4 automatic
:deadhorse:
do you have a lift installed, i.e. was your drive shaft contacting the fuel tank skid?
NO its stock....It has since come back and I have put the zirk back in. Its just something we have to deal with I guess. Super annoying but im gonna try just absolutely filling it with grease this week and see what happens:washing:
Dear all: haven't visited the forum since 20 Oct 2011 -- good to be back! My wife and I still have our excellent 2003 T4R V8 Sport (+250,000K) in perfect condition. It's her DD and we have maintained it faithfully over the years. At the suggestion of the Toyota dealer where I bought this vehicle (used), the driveshaft was replaced under warranty 08 February 2008 -- part number 37110-6A480. This was because of the "clunk" was very pronounced and bothersome. After the work was done, the clunk was like a weak echo of it's former self -- very, very faint. Now, 72 months after the replacement, the "clunk" is often not there at all, and when it is, it's hardly noticeable. The drivetrain is fully lubricated once a year. No other service or replacement work has been required or done in that system since then. I have no idea if putting in the Lexus driveshaft as a replacement was the thing that made it quieter -- could be, or maybe it was something else. But since it was done, things have been very good on that front. Hope this helps ... Cheers / Blueleezard
Since when did dealers replace 4-Runner driveshafts with Lexus driveshafts "under warranty " . My recollection is that Lexus replaced their driveshafts under warranty but Toyota never did . I gave up on my 2006 Sport , which now has 193,000 miles long ago when after many complaints, I was told it was a "maintenance issue" and regular lubrication was the fix and I was responsible for doing it .
Since when? Well, maybe the dealer where I bought our used 2003 V8 Sport never got the memo to not replace the driveshaft :D.
But I was seriously impressed with how they dealt with this situation back then, and am still very happy with the result. And I keep every receipt for everything ever done (not just on the T4R), so I have the dated paperwork for the warranty replacement (no personal cost) and the part number to prove it.
I recall having a discussion with the service manager at the beginning of all this to talk about the clunk. I took him out one awful morning for a test drive in very bad winter conditions. I made sure to do donuts in a vacant parking lot, slam and then feather the brakes, fwd and reverse in high and low, lock and unlock the differential, controlled 4-wheel drifts (without crashing into anything), slow and then very rapid acceleration, etc. etc. -- perfect for demonstrating the clunk, over and over again. He then drove it too, made it clunk repeatedly, absorbed all of that experience, and agreed that work was necessary.
He immediately suggested even before we got back to the dealership that all the universals should be fully inspected, etc., and that the driveshaft might need to be replaced. So, as soon as we got back, the full inspection took place. When they didn't find anything, he orderd the replacement driveshaft, arranged the appointment, did the warranty paperwork in the background, and then a week or so later the full job was done.
I also recall that the difference in part numbers between the Lexus and Toyota driveshafts is only the last digit in the string, one number different. BTW there was no argument whatsoever from Toyota Canada about covering the warranty replacement and labour costs -- it was accepted right away and went straight through.
In our case, I think we were very lucky to have the Lexus driveshaft replacement suggested by the dealership and then carried out so efficiently. And, success of the replacement without any further intervention has been very well demonstrated, now over the past 6 years.
For whatever reason, the dreaded drivetrain clunk seems to be a symptom of some kind of design fault that, to my knowledge, has never been resolved by Toyota. It may have to do with tolerances in matching splines, or something like that. So it could be that the Lexus tolerances are slightly "tighter" than those in the Toyota version. If so, that would snug up any "slop" that might otherwise generate the clunk, but still permit the necessary movement of linked-up moving parts.
If this sounds plausible, maybe such a difference in tolerances would be on account of a difference between wherever either Toyota or Lexus sources parts such as driveshafts -- which country, which plant, which manufacturing line, maybe even which materials, etc.
BTW, I am not an engineer of any kind and don't work in the automotive industry, never have -- I just do one hell of a lot of reading.
Again, I hope recounting this story might help, somehow.
Cheers / Blueleezard :cheers:
Any Toyota dealers in OC/LA that knows how to use the right grease and lube the right zerks/joints? I've been to Toyota Irvine and Tustin. Irvine's better, but I'm not confident they lube the prop shaft and joints correctly.
Thanks.
Most dealers simply use 1 type of grease- mine included.
Have a look the link below - it is for older years but it's a good read and the new manuals probably have similar "suggested" maintenance.
http://www.toyota-4runner.org/3rd-gen-t4rs/97006-drive-prop-shaft-greasing-guide-2.html
I've used Lucas #1 Red and the #2 Green in ujoint zerks and driveshaft zerks no u-joint failures or driveline failures yet.
I did just buy the Amsoil 5% moly ngli #1 & ngli#2 and I'll try those next.
NEW drive shaft
I had the infamous vibration form a bad u joint. Also found out that the drive shaft is NOT serviceable. After my initial rage, I started my search for an aftermarket shaft, I was NOT going to buy a new one from the dealer considering its NOT serviceable. After some much needed whisky and some research, I found a place. Got a NEW aftermarket shaft that is SERVICEABLE.
Cost me about $690.00 for a complete NEW, not used or refurbished shaft. I can replace the U joints in the future, should have been the case with original but Toyota does NOT agree apparently. Installed two weeks ago and all is well. Mechanic was very impressed with quality and price.
Got the drive shaft from : wholesaleimportparts.com
What year and model? An unserviceable drive shaft is news to me and probably many others.
Very noisy but lovely car
Hello guys
How are you ? I'm a new friend of you from Saudi Arabia and a new owner of a 4Runner 1992 4WD . unfortunately I have a problem with my 4Runner when approaching a speed of 90km/hour , it starts to vibrate and it gets noisy that I can't enjoy my music hahahaha
I removed the front drive shaft and the vibrations gone , but because I always drive offroad I can't keep it without the shaft
Can any one of you kindly provide me with the price of a new shaft
1110596834
I have a new 2016 4runner and i have the same thing, stopped at red light, get a lurch like someone tapped my rear bumper. it makes me look back to make sure nobody hit me. I've searched around the forum and noticed a lot of posts of this but seems to apply to 2010-2012 etc tacos and some 4runners, I have not been able to find anyone posting similar for their newer 4runners. I've read previous posts of replacing the drive shaft by blueleezard but his vehicle was an 03.
I assumed since the TSB is on 5th gen that it would apply to the 16 but the TSB specifically called out the 10-12 vehicles.
Some help?
If you're mechanically handy, crawl under the side of the 4R and pump enough grease into the drive shaft slip joint until a quarter-inch of shaft appears. You'll see what I mean after 5 or 6 pumps.
Otherwise ask the stealer to do it.
i've read this is only a temporary fix? vs replacing the driveshaft?
I have yet to read anyone reporting this issue on their 14-16 4R :(
I did two rounds of grease on my 2005. Haven't heard a sound or felt a thump in 8 or 9 years. It's your vehicle and your choice how to fix the issue.
I've called 3 toy dealerships
1 said it's normal and there's nothing they can do about it, any previous fix does not work
1 has no clue nor has ever heard about it and asked to put a code reader on it and test it
1 has never heard of it neither but will look into it.
......sigh
Save yourself a bunch of aggravation and just pump some grease into the fitting. Above all, avoid the stealer that thinks a code reader will identify the problem.
RennSport2UZ
