Driven for a prolonged period in Low 4, front end shot?
HDRunner
Hi everyone,
I've got a '91 4Runner 5 speed and I would like your opinions please.
I've had the vehicle for 6 months and when I got it, it was known that the clutch would have to be replaced. A couple of friends and I replaced it approximately 2 months ago, and I believe since the clutch replacement, the 4Runner has been driven in Low 4, constantly. I think when we replaced the shifters and what not, the 4wd shifter was placed in the Low 4 position and has been there ever since. The 4wd light apparently does not work on the dash and I think I've been driving around, blissfully ignorant of 4wd being engaged.
I pulled out of a gas station this morning and there was a patch of ice at the exit. I heard the front wheels spin on the ice and thought 'Oh SH*T! This things in 4WD!' I stopped and set the shifter to H2 and at that point realized that the shifter had previously been in the L4 position all along.
A month and a half ago (pretty much right after the clutch replacement) the front end started shaking mildly and the vehicle would pull to the right. Since then the shaking got a lot worst and I noticed uneven tire wear on the driver side front.
The first bit of advice I got was to replace the tire and get an alignment. Fortunately, the guy I got the 4Runner from also gave me 4 additional tires that were already mounted. I replaced that drivers side tire with one of those and the shaking stopped...temporarily.
We use the 4Runner pretty much as a point A to point B vehicle, just to get to work and to the store and I never did get an alignment done.
Within the past 3 weeks I have switched the driver side tire twice and the shaking and pulling has pretty much rendered the vehicle un-driveable. The tire changes no longer 'put a band-aid on the problem'. A friend took a peek at the front end and said it looked to him like the driver side CV axle was shot as well as the upper ball joint.
I imagine prolonged driving in L4 on level pavement at speeds up to 60-ish is no bueno. Do you think this could have caused this issue and how much damage to the front end components could it have done?
Thank you,
Scott
DJNutshell
