Driver door ding w/ key in ignition
tral
Not the end of the world but interested to see if others have this issue.
Key in the ignition w/o T4R on and door ajar. i sometimes get like 3 dings or so and then it stops, will proceed as normal or stop all together. there is no pattern that i can come up with.
tr
tr
Not enough info given, it should be - Door is initially open in all cases
Key in Ign/Lock - Infinite beeps
Key in Ign/Acc. - Infinite Beeps
Key in Ign/On. - 5 Beeps, will not reset if you close the door and re open
Key in Ign/Run (ie engine running) - 5 Beeps, will reset if you close the door and re open
sorry. most of the time this is all correct however.
Key in Ign/Lock - Infinite beeps - sometimes 3 and stops, sometimes not.
Key in Ign/Acc. - Infinite Beeps - sometimes 3 and stops, sometimes not.
Just interested if folks get this in theirs or not sometimes.
