Driver Side DRL Stuck On
EHNWI
Member
Hello, I just wanted to know if anyone else has had this happen. I imagine it's some sort of electrical thing, but I know very little about electrical issues in vehicles.
My drivers side DRL is stuck on while I am in low beam mode. Since they also act as turn signals, the driver turn signal is very weak, while the passenger is working normally. Any advice on diagnosing this issue would be much appreciated. Thanks!
either its shorted to something else or the relay could be stuck. try swapping with a similar relay and see if the problem persists.
Do you know where I could locate the relay or find the short?
The DRL/Turn Signal Relay is on the back of the Driver's side Junction box. Box is under your dash and holds a bunch of fuses.
To find a short I'd start at the bulb connector, look for broken/exposed wiring.
Thanks, I appreciate the help. I will check it out.
charlesz
