Driver side Passenger rear window wont roll up?
bpowa
Well This past weekend I had my buddies in my truck and the rear wondow would not roll up on the driver rear passenger door.
I can roll it up and down on the driver combo switch but the switch on the actual door rolls down but not roll up?
Any bugs and fixes you guys can guide me to?
Try using the passenger side rear window switch on the malfunctioning door. If it works, you need a window switch.
Sounds like the switch at the RR door is bad. You should make sure the connections are good of course, but if it works with the Master switch, the motor and wiring are good. You can also swap it with the LR door just to be sure.
Rialm
