Drivers Side “A” Pillar Grip Handle Installed on 2014 -2025 T4R
[MENTION=123707]FZRunner[/MENTION]
See post 110...……..
Trying to troubleshoot your issue!
I got my parts from McGeorge Toyota online. It’s the left hand grip. My interior is gray, as are the part numbers as listed in the first post. You might be better off going to your local dealer and ordering there to verify the color in case you have a tan interior.
But just in case, here are good online sources for parts:
Online parts dealers
McGeorge: Toyota Parts | Toyota Online Parts | Genuine Toyota Parts | Toyota Parts Online
Conicelli: Genuine OEM Toyota Parts | Conicelli Toyota of Conshohock
Olathe: Toyota Parts Online | Olathe Toyota Parts Center
Camelback: Toyota Parts Factory - #1 Source for Genuine OEM Toyota Scion Parts & Accessories | Camelback Toyota Parts
OEM Partsource
OEM Part Source | Genuine Toyota, Honda, Ford Parts and Accessories | OEM Parts
Thank you very much!
Drivers side grip
I’m interested in one of your kits. . . . . . Now have to go back and figure out pm process. . . . . . I’ll call my grandson
[MENTION=154554]Jasontamu[/MENTION] sent email to order a kit. Thanks so much for making this solution!!
hi all, i have replied to quite a bit of people on PMs and emails. please if i haven't responded or missed you email me again just in case.
i got another batch back from my welder and filling in more orders this weekend with shipments going out monday am.
thanks so much and happy new year all.
-J
-J
Just re-replied via email that I sent funds via PayPal.
Also ordered the handle and covers.
Thank you for sharing this mod
Sent from my SM-G955U using Tapatalk
Sent funds to your paypal. But forgot to leave my username on the forums. But I'm the one that needs it shipped to Canada.
I just did this last night. It’s a great mod [emoji1417]
Drivers Side “A” Pillar Grip Handle Installed on 2014 T4R
Is your bracket holding the "A" Pillar Cover out?
IF so you can cut that hole larger so it does not hold the cover up/out....
See my pictures in the 1st post.
Yes I have a bulge as if the bracket is too tall. The round part under the handle actually passes thru the A pillar cover, cutting the whole bigger may not solve the bulge.
But are you referring to the clip? So the opening needs to be cut larger diameter so the clip clears ?
But are you referring to the clip? So the opening needs to be cut open so the clip clears ?
Yes, I had to cut the opening large enough for the clip to clear. But be careful so it’s not too big or the opening may show. Also, with the cover installed I found that the white nylon base on the lower attachment point of the handle needed to be shaved down to make it fit flush with the surface of the cover.
seltzernator
