Driver's Side Passenger Window Anti Pinch Problem
CutthroatSlam
Senior Member
Since installing the seat warmers, where I had to disconnect the battery so as to not set off the air bags, the passenger window on driver's side goes into anti-pinch mode when it hits the top of its run and drops down like 3" to 4". Only way to get it to the top is to inch it up in steps with the button.
I've tried the hold the button in the down position for 10 seconds, then the same for the up position but it immediately drops down when I try to hold it in the up.
Any suggestions on how to reset this?
Try holding it down for longer. I had the same type of issue. Held the button down and then up for 30 seconds or so
I held it in the down position for a minute, but can't hold it in the up position as it goes into anti.-pinch mode with the window dropping half way down. Sounds like the permanent fix is pulling off the door panel to do an adjustment on the window regulator, but that will have to wait until the warmth of summer.
Update: Watched additional videos on this and you need to do the reset using the button in the door. I was doing it from the button in the driver's door. Now it is working.
How to Reprogram Power Window Switches on a Lexus/Toyota (Don't Work After Changing the Battery) - YouTube
Talyn
