Driving Issue
4runnerman09
So i changed my oil in my car and i also for the first time i greased my driveshaft. i'm not sure whats going on but when i accelerate i'm getting almost like a traction control feeling. the car holds back then i get a burt of power then it holds back. this happens when i mash on it or just accelerate normally. Any ideas?
hmmmmm?
Sounds fuel pump or line related. Need to know more. Does trac light come on?
Dry road?
Does it hesitate once you are above 35mph as well?
What does "I get like a traction control feeling" even mean? Are you sure you drained the oil pan and not the transmission one??
No guys I drained the oil not the tranny. So this is what I did ... Disconnected the battery and everything is perfect now. Idk of it will come back. Yes I was on dry roads and yes even if I would accelerate from 50mph.
To answer the question of the traction control. So let's say your making a right turn from a stop and you punch it. The car will hold the throttle until you you get straightened out there is suddenly a explosion of power. I'm sure you know what ment.....
Do you still think it might be a fuel pump after the reset?
