Dumb question, did I get the right 5100's?
AfroWookie
I was talking with a friend of a friend the other day and he was saying that there are a couple different models of 5100's for the rear of our trucks and it got me wondering if I have the correct ones. Here are the ones I have, only 1 pair is adjustable, which is the front. I'm not home right now to give part numbers, but I can look when I get home if need be
thats the same type i have on my truck, measured it b4 installing..it was about 2 - 4 inchies taller than the oem i removed. bought it on amazon
There is only 2 part numbers for the 4th gen 5100's, one front and one rear. The fronts are adjustable, the rear are not (since the rear is not a coil-over design, there is no way for the shocks to provide lift). As long as you ordered for a 4th gen, you should have the right parts.
Side note.....Bilstein did change the part numbers a few years ago, but everything I've seen recently is the newer part numbers. It was still the same shock, just a different part number.
Did you order from Down South Motorsports? Those are identical to the ones they sent me a few weeks ago. They are the same as all other 5100's for the 4th gen but they are labeled with an RCD sticker. Something to do with a backorder from Bilstein on the regular ones is what I was told by someone at DSM.
Same shocks, just different sticker
Awesome, thanks!
Yep, ordered from Down South. Awesome price and super fast shipping
Bilstein, Innovation and High Quality Since 1873
Fronts:
Part Number: 24-186711
Series: 5100 Series (Ride Height Adjustable)
Position: Front
Descriptor: Excludes adjustable (X-REAS) suspension
Descriptor: Front Lifted Height: 0-2.5"
*Collapsed Length (IN): 17.03
*Extended Length (IN): 22.56
*Collapsed Length (MM): 432.5
*Extended Length (MM): 573
Old Part Number: F4-BE5-C475-H1
Rears:
Part Number: 33-187174
Series: 5100 Series
Position: Rear
Descriptor: Rear Lifted Height: 0-2"
*Collapsed Length (IN): 14.91
*Extended Length (IN): 23.5
*Collapsed Length (MM): 378.8
*Extended Length (MM): 597
Old Part Number: F4-BE5-E703-H0
BillM777
