E-Brake problems!!
MyHigh
So I'm to the point where I think my E-Brake cable is in need of replacement. So far I've done new pads, drum, and bellcranks.
My problem is, when I pull the handle up to engage the brake it's real tuff to pull. From the first click I'm experiencing resistance. Then when I go to release the brake I push the button on the handle and the handle falls to the resting position and does not release the bellcranks. Now I have no resistance on the handle at all I can pull it to the original position before releasing or anywhere In between. I also notice the cable inside the center counsel is lifted to where the handle pulled it up the first time, in order to get that cable to retract I have to go around back and hit the bell cranks loose.
Now the bellcranks are fine I replaced them and they are free moving when no cable is attached.
I also noticed the cable where it connect to the second cable that runs along the axle is missing the boot that fits over the end, so I'm thinking it's corroded and binding up.
Is that cable hard to replace? And get everything properly aligned?
It's really my last option seeing how I've done everything else.:mmph:
Oh yeah it's a 5-speed
It's actually pretty easy. You might be able to grease it if you'd want to try that first.
It's just like replacing a clutch cable on a bike. You should have it all done in under an hour.
Maybe just take it apart and lube it. If it doesn't accept grease then replace it
Sweet! That's what I needed to hear!! Thank you shootmymime I think I will try and lube it then, unless it's under 50 bucks then I'll just buy one ....lol 50 bucks yeah, right!!
Did it last year, easy enough job, mine was seizing where the cable is booted near the wheel. Lubed several times, finally replaced it, so glad I did!
Took pics and did an informal how-to for a manual truck, have part number of aftermarket cable-
post 1369-1379
habanero's 1996 4Runner Build-Up Thread - Page 68 - YotaTech Forums
Cable was 54 bucks at Advance, paid less with their promo codes....search around.
Be any chance did you try adjusting it? On the passenger side of your e-brake handle there is a stud with a nut on top of it. You can adjust this to see if it helps before replacing. When I bought mine last year I had to replace the bell cranks and mess with that adjustment some.
goddesszilla
