Tyler James Inc
Senior Member
Ticket for the first one, rear end collision for the second?
Never have I gotten a ticket for a light out, nor have I been rear ended. But sure- I suppose if all three of your brake lights go out at the same time, that could result in a horrible accident. Not likely to happen with a turn signal, but still possible, for sure.
The reason you get hyper-flash with incandescents, is because the flasher works off of resistance. When a bulb goes out, the resistance in the circuit goes up- one less path for current to flow- resulting in a faster-acting flasher relay.
I believe the electronic flashers will blink at the same rate, regardless of resistance in the circuit.
