BlackCat914
It can help the life of the trans because it works less but I agree, no way will any boost help a motor last longer.
so it can help a trans last longer because it works less, but not an engine?
All hot air...there's no way you can argue that adding extra pressure to engine internals is better for a high mileage engine than a lower gear ratio.
Depends on how you drive it. Before i did the S/C on my truck, i had to keep the throttle pinned at 4000+ rpm to get over some of the passes here in CO. With the SC, i can drive it a lot easier and it gets better MPG to boot. Perhaps even though it is being driven easier, it may still be subject to more wear because of the boost. Who knows. Its way more fun to drive though.
Dialing in turbos is not as easy as you think. You get lag from boost leaks. I owned turbo cars from age 15-28 and I battled boost leaks the entire time. Boost leaks at every coupler, weld, throttle body seals, gaskets, intake manifold, injector seals, pcv valve, turbo to manifold. WHen you add turbos to cars that dont have one it becomes a huge PITA to keep it running perfect. I could not imagine one on an offroad vehicle. It would just be that much harder. I was in my garage every weekend running boost leak tests on my compressor trying to fix them all.
In my opinion, I think a small turbo (T3/T4) would be superior to the TRD supercharger. Sure both can make 7psi, but you'll see more gains from a turbo with that 7psi than you will a roots blower. The parasitic drag of the blower robs you of more HP.
This is a slippery slope with the ATs in the 4runners. You are creating more hp with a turbo or supercharger so unless you lope it along you are going to cause more stress to the clutch packs under acceleration. A number of people experienced slipping transmissions after adding an S/C and 7th injector. Add a smaller puller (S/C) for more boost and/or meth and you will speed up the process. Re-valving the valvebody (Level 10 or IPD) are some of your only options short of having a more robust tranny (insert horrible internet tranny photo-here) built. :bolt:
josh
If you stab the throttle in any of my Supras/Subarus/Volvos, the engine doesn't respond nearly as quickly as the 4Runner and that's because it doesn't have to feed air into 7 feet of pipe before it reaches the cylinders. And if you need a 7th reason, turbos eventually bake every single wire and hose in your engine bay due to the heat--the SC does not.
I used to be a turbo guy but I'd never go back now.
Regarding the ebay kit, looks nice, but the stock fuel injection won't be able to deliver. There are hidden costs.
No offense but you've probably owned some terrible turbos in your days. I'm not backing this kit but buy a quality turbo and you will have none of those problems. You guys can't compare shit budget build turbo's to having a proper set up. Turbos are coming back fast in the automotive world, bmw 328i, ford f150 both great examples, more power and more fuel economy. F1 is going back to turbo's next year as well, there will be a big swing from displacement to force injection in the next 10 years as the cafe requirements start to hit the oem's hard. If it is done properly you will have no problems with boost leaks or wires or whatever the hell you are saying will break.
to clear another thing up I have noticed in this thread, psi is meaningless, cfm is what is important.
We have 4runners, which are SUVs btw. If you're looking for a crap load of power, get a different vehicle. If you want just a little more oomph to help you overtake cars or pull heavy loads, don't even bother looking into turbochargers, go do bolt ons or regear yourself. Many people get in way over their head with turbochargers not realizing how much work it takes to get it to run reliable.
When I was into building cars I learned one important rule:
CHEAP, FAST, RELIABLE.
You can only pick two out of the three.
