Eibach Front Coil Over Springs $140
sn0wrunner
I have a set of Eibach springs that I ran on my 3rd gen for a little while. Only have about 1000 miles on them. They are in great shape. Asking $140 shipped to anywhere in the lower 48.
They are a 14" coil, 3" diamater, and the spring rate is 500 lbs/in. They are coil over coils and flat at both ends, so they will not work on the stock spring perch, or any other spring perch that is meant for coils with a pig tail end.
Coils pictured are coils being sold.
DSC_0219.jpg~original
replied to your pm.
They ride great. I swapped them out for some longer ones that also have a 500 lb spring rate. I had to crank these ones up too high to get the amount of lift I wanted (4-4.5"). But they rode super smooth. Definitely will want a sway bar on for hwy driving with these coils. But they flex great off road.
Yep still available.
I updated the first post with more info. These are coil over coils, and will not work with a spring perch that is meant for coils that have a "pig tail" end. They are flat on both ends.
If you have coil overs already, and want a softer spring rate, then these are what you want.
upanatāt
