I apologize guys, my package got delayed over the weekend and I was just able to pick it up at FedEx. Will be installing them once I get home, pictures and info will hopefully be posted up tomorrow.
Can someone please help me flip the pictures...I’m away from my computer and posting from my phone at the moment. That might be why it’s flipped.
Thank you.
Thank you.
Looks good. The most accurate way to measure is fender to the bottom of your rim. Then measure diameter of the rim and divide by 2. Subtract 1/2 of that diameter and that will put you smack dab center Everytime without an error for eyeballing itAs promised the springs are installed, not going into detail on “how to”....plenty of videos on how to replace them. Tried my best to dial in the measurements but it was 100 degrees and I was trying my best to get it done quickly and efficiently as possible. So here are the measurements and pictures. I apologize for the upside down and sideways pictures, not sure why it’s doing that?
Before:
From the ground
Front Left 35 1/8
Front Right 35 1/4
Rear Left 36 5/8
Rear Right. 37
From the center wheel(Which was hard to find center)
Front Left 20 1/2
Front Right 20 5/8
Rear Left 22
Rear Right 22 3/8
After:
From the ground
Front Left 37 1/4
Front Right 37
Rear Left 38
Rear Right 38 1/4
From center wheel
Front Left 22 1/2
Front Right 22 1/2
Rear Left 23 1/4
Rear Right 23 1/4
Will measure again when I put more miles on it and see where the final numbers are. Overall the front seems to be about a 2” lift and the rear is set at 1”.
Yes Prolee,
Looking good. I’m definitely leaning that way for my AG Pro. I hope I can fit 285’s on my SCS wheels and clear the front.
Thank you sir!
You mean, mam... and you're welcome! Can't wait to hear about ride quality and your thoughts, etc!
I apologize...thank you Sunshine! :kiss: Will update on the ride quality next week after it settles a little bit more. As of now it does seem to ride stiffer but with a little bit more noticeable noise dive, may be due to the center of gravity now that it sits higher.
I was also able to get side by side shot with my Nephew's stock 19 ORP. Hopefully it will give you guys a better reference on the lift.
By the pics Prolee,
It’s definitely a noticeable difference.
Looking forward to installing mine...they finally showed up today.
ProLee, i'm guessing there was no issue installing on the two different perch heights on the FOX's?? The springs are clearly identical in height.
AMLOR
