EL012-06- Nav shows vehicle in wrong location
i know this is an old thread, but, i had a perpetual issue with this and imo had nothing to do w the disc. I found the sequence of screen touches (on this site) to get to the service menu of the nav, and from in there you could see that the GPS was only getting 1 or 2 satellites. even took the car to the dealer to see if there was an antennae issue, they couldn't find anything...surprise surprise.
what i did to fix it myself was simple...i disconnected the battery for 10-15minutes. once i reconnected the battery and fired up the system I was getting a full bank of sats connected...issue went away and hasn't come back since...
the new NAV discs take away the back door into the service menu of the nav, so i never updated. why? because you can go into the service menu and select OVERRIDE which allows you to use the nav while the vehicle is in motion
Not sure if i overlooked this and it was posted already but i searched through the thread and forum and didn't find it.
for 06 and 07 4runners
Hi Prhime,
Like you same issue happened with me, though i have search again n again but didn't get exact solution. :mad:
