Elocker Wire Harness Routing
rjaudi
Does anybody know where the factory elocker harness attaches to? The factory harness I have has 2 brackets I bolted the small one to the elocker, but I have no idea where the bigger bracket bolts to. Also, where am I supposed to clip the plastic breather hose?
i believe it mounts to the top of the drivers side shock bracket.
And the breather, I ran inside with the wire harness.
The breather has a small clip, I mounted it up as high as possible under the car. You can see it and the two brackets in the upper left of this picture.
I replaced the entire wiring harness from the dash back when doing my e-locker swap, but unfortunately I don't have any pictures of under the truck. As mentioned the 2nd bracket bolts to a captured nut on the top shock mount.
- Matt
Thanks guys, I 'm just going to zip-tie the breather up as high as it will go. I have the elocker wired and its working perfect.
DJNutshell
