Eng oil analysis question
RS Dude
Member
I have had a minor coolant leakage problem for some time now. I cannot find any evidence of leakage from any external components. My conclusion is perhaps my head gasket is going bad, though I have no signs of evidence of this, such as, white smoke from exhaust.
My question: Will an engine oil analysis (from Blackstone) be 'definitive' proof of head gasket failure if they find any glycol in the engine oil?:confused:
If you are getting any amount of coolant in your oil you'll also be getting oil in your coolant. And your oil will turn milky. Do you change your own oil?
I do change my oil.
From visual inspection, I can see no cross contamination in either the oil or coolant.
I contacted them asking the same question and they said, yes, they can tell if you ask them to look for it.
How long ago was your water pump changed? Miles/years
Pump and timing belt have 110,000 miles and were done about 10 yrs ago. Also, I had TWO ! head gasket replacements, both covered under the recall campaign.
As a starting point, suggest you replace radiator cap if you have not done so in last 2 years. If it relieves too close to operating pressure, it can cause slight coolant loss over time. If you have the tool, best to test it to confirm if it is a problem but, if not, just replace it as it is cheap.
Buckaroo
Buckaroo
Cap is only 1.5 yrs. old. New thermostat also 1.5 yrs. old.
Typical headgasket integrity tests include
1. Looking for combustion gasses in the radiator headspace
Super price on UView 560000 at ToolTopia.com
2. Compression test/cylinder leak down test
3. Measure cooling system pressure w/ gauge - rapid increase after starting or erratic pressure indicates issue
Other less accurate indicators -
1. Remove cap from radiator and run engine - look for bubbles coming to surface of fluid,
2. Remove oil dipstick and hold tip to open flame - should smoke but not catch fire - if it does, indicates presence of unburned fuel.
3. Put drop of oil from dipstick on hot exhaust manifold, should smoke - spatter/boiling indicates presence of water.
Buckaroo
I'd say its time for a water pump I bet the weep hole is leaking. They are 90k mile parts at best and about 5 years. I'll bet head gaskets are fine just time for timing belt and water pump
TerryNap61
