Engine compartment light mod
Thanks for the great idea.
I've got miles of led strip lights around (ok, not really miles--- but a whole bunch), so using you're brilliant Idea, I added them under my hood and the difference is like night and day... literally.
I went with a pin-switch to trigger them because I like trying to catch the lights coming on and going off-- like the light in the fridge when you were a kid, remember? Actually, I just didn't want to have to fumble around in the dark to find the switch, and thought it would just be more convenient to always come on when I open the hood.
I tend to be a bit anal at times, and spent entirely too much time trying to decide exactly where I wanted to mount the switch.
The dilemma I faced was that I didn't want to put the switch in a position where it could snag on something (me) if I happened to be careless enough to lean over it with a loose shirt, but I also wanted to make sure that the location I chose was reinforced well and made solid contact with the hood, so that I wouldn't have to worry about rubbing, or a poor connection over time.
My solution was to mount the pin-switch inside one of the rubber hood stops...
First, I had to drill a hole through the middle of the stopper so the switch could go all the way through and open/close without rubbing at all (since the switch has to move freely in order to complete the circuit when the switch springs up).
Since the pin-switch is normally grounded by the very nature of it being mounted securely to the bare metal, the fact that I was embedding it in a reasonably solid chunk of rubber meant I had to come up with some other way to ground it, or find some way to defy everything I knew about electricity.
I ended up taking the lazy way out (hint--- I didn't defy any principles of electricity).
To ground the switch, I ended up soldering a length of wire to the pin-switch housing using a propane torch then attached that wire to a pre-existing hole in the metal radiator support (but not yet).
With the Rubber stopper taken out (it unscrews-- it's actually designed to adjust the height of the hood when closed-- go figure!) I pushed the pin switch in so that the pin was a bit higher than the top of the bumper, but made sure that there was more travel left in the switch below the top of the bumper. I still wanted the bumper to support the weight of the hood when closed instead of the switch, to give the switch a chance to live to a ripe old age.
Ordinarily, the pin switch needs to be fixed to the vehicle with a lock washer and nut, but in this case those were unnecessary. Since the switch was firmly seated in the middle of the rubber bumper, by the time I had replaced the bumper in it's original location (by screwing it in), the rubber was being compressed around the switch keeping it firmly embedded in place.
Once the bumper was back in place, I made sure to readjust it's height so the hood would be level when closed, then finally, after all that was done, I secured the wire (remember the one soldered to the switch housing?) to an existing hole in the radiator support.
Of course I also ran the + side of things to a fused 12V feed, but that's boring, so I'm not going to waste time on that part-- since I'm lazy.
Anyway, I know this was way longer than it probably needed to be, and the real purpose of this thread was to show how brilliant Snooperstyle's mod was, but I thought this trick for mounting the switch might come in handy for others out there looking for switch placement ideas.
Thanks again for the light idea Snooperstyle-- it is was a great solution to an odd feature omission by Toyota.
Just be sure the light shines on the big motor ON-OFF switch.
Flipping it back ON is about the only thing you can do under the hood at night.
You are welcome! What you did is kinda what I was gonna do, and then I just couldn't find a switch like that, so I ended up using some old thing I had laying around in the garage. Even though I wanted a pressure switch originally, I ended up liking being able to turn it on and off manually because then it doesn't come on during the day, which is when I have the hood open 95% of the time...not that these LEDs really take up any juice...but still...
Here ya go:
Tiny LED Modules : High brightness surface LEDs
I would caution that these are really small...so look at the exact measurements before you buy. I thought that they were gonna be a little bigger because I didn't look at the fine print...I still think they are great, but I had to use four of them instead of two, which actually turned out looking really awesome!
What I put in my hood is TWO of the round ones on the outer edges, and then TWO of the long ones for the middle ones. I got the white ones with black housing. All four of them put out the same amount of light roughly...if I had to say which one puts out more light, and it is really close, I would say it is the long ones...both have 6 HP LEDs in them...
More on the switch: The location of this switch that I mounted is right next to the rubber stopper, and it is flat under the hood right there, which should make for good contact with the right switch. This did involve me drilling a hole in the panel there, but only in the plastic, not in the metal underneath...there was already a hole there! It is very tight underneath it, and it might involve removing this switch to access the light housing but I AM NOT SURE...didn't try!
Great feedback - thank you for taking the time to post.
This mod is one of the very next for me. May adjust LEDs (size), as you described, and add a switch vice a pin switch.
MOD is a must have (IMHO) as many of my others are "nice to have".
Good stuff.
Thanks again
S
There is a bit more info on this in my build thread but a quick snapshot - These are LED strip lights from VLEDS.com very, very high quality, 3M adhesive, and way brighter than necessary. I wired em to a SPST switch in the engine compartment as opposed to using a tilt switch or momentary switch triggered by opening the hood so I can decide when the light comes on.
IMG_5775-1.jpg~original
IMG_5774-1.jpg~original
IMG_5772-1.jpg~original
IMG_5771-1.jpg~original
I did the same thing as SOcalTRAIL. I also bought my led's from V-LEDS and installation was a snap. Used a relay and also mounted the switch right on the plastic radiator cover (right side - or near side in the picture below). :reddance:
<a href="http://s1089.photobucket.com/albums/i348/klang0/?action=view&current=photo-24.jpg" target="_blank"><img src="http://i1089.photobucket.com/albums/i348/klang0/photo-24.jpg" border="0" alt="Photobucket"></a>
I know absolutely nothing about electrical wiring, but must have this mod. Can you please tell me exactly what items to buy for this mod? I already bought:
<> 16ft Waterproof 5050 300 smd lead strip in cool white
<> A green lighted on/off spst 12v 16 amp 3 pin dc switch
What else do I need to wire this and exactly how should I?
An inline fuse? what rating? Wire to run? what type? straight to battery or do I need a relay or something else?
Sorry for asking for the "baby steps" guys...I literally never wire anything, but want to do this myself. I still have the backup light mod to do and already bought the switches and lights and upgraded bulbs and still haven't installed them because I don't know how to run the wiring.
Wire is pretty important in wiring things, so start with that - 18 or 16 AWG primary wire should be fine; get one spool of red and one spool of black for easy designation when you wire it. If you have a 16ft section of LEDs you'll also need something to cut the LED strips to make them shorter (box knife should be fine for that) and the following items:
- Soldering Iron
- Rosin core solder
- Heat Shrink
- Heat Gun or Hair Dryer
- Electrical Tape
You don't need a relay for LEDs, and an inline fuse will work fine. Determine fuse size based on the gauge wire you're using (which is determined by the load you're putting through the wire), but for this purpose 5 amps should be plenty unless you keep your LEDs at 16ft...
Thanks limamike... You da' man!!!! I will post pics when I get this and my rear backup lights in
Last question... When I put the rear backup lights in and these engine compartment lights do I just run separate wires all to the battery for each set or is there a hub type box that I should get that each set of lights go to that then connects to the battery?
If you plan on doing a lot of wiring mods, get one of these: Amazon.com: Blue Sea Systems 5028 ST Blade Fuse Block with Cover: Sports & Outdoors
Wire that directly to your battery with an in-line fuse, then wire your accessories off of that. Ground each accessory individually.
Thanks for all the help! This mod is GREAT! Here are some pics of my install. I cut a 30 inch strip of LED's, ran them to a green toggle switch and added an inline fuse. I put the mini blade type fuse inline with a 5a fuse. Everything came out really clean. I put the switch on the plastic trim by the driver side head lamp so it wouldn't be touched by accident by me or anyone else.
You just had to make sure you showed all of us your V8 didnt ya!:jk:
erinobr2000
