Engine diagnostics code 12, 1991 4runner 3vze
Jonyale420
I need help! I have a 91 4runner with 248,000 miles, 5 speed V6 (engine was rebuilt last year and has less than 10k miles on it). I was on my way out of town a few weeks back and it died on me. The morning before, I was leaving my house and it stalled out for a split second then jump started right back up. A mile down the road, it did it again. I changed the fuel filter that afternoon and thought it was good. The next morning, I loaded up the kids and we were off on an off road adventure. We made it about 10 miles away and it stalled out again (I was going up a nice long grade) and took a little longer to bump start. Kept going and it did it again but would not start back up. I coasted backwards down the hill to a turn around spot. Once I was facing down hill, it fired right up so we continued on our journey. We made it another mile before it cut out again. I was able to get it off the road and figured I needed a fuel pump. I pulled the check engine codes (no light on) and it was flashing a code 12. I had it towed home. I checked the distributor and it read
G1-G 493 ohms
G2-G 495 ohms
NE-G 235 ohms
I have since checked every distributor I can find in junk yards and auto parts stores. None of them seem to check out good, not even the new (not rebuilt) distributor I bought yesterday (G1-G was 523 ohms). I have replaced the ECM, coil and igniter (all from junk yards). I checked the voltage from the ignition switch to the ECM. It has 9.4 volts while cranking The truck has been sitting in my driveway for 2 weeks now and will start up every morning. I can turn it on and off a couple times or let it idle for 45+ seconds and then it dies. After that, it will not start again until the next day. I can smell fuel when I try to crank it and I can hear the fuel pump turn on when I jump it at the diagnostic box. If I can not figure out the problem soon, I am going to have to take it to a shop (I have not taken any vehicles to a shop in more than 20 years)........another question I have is Are there any GREAT Toyota shops in the San Diego area?
Thanks for any and all help
You might consider replacing the EFI relay , or see if your getting power through it. Then, ohm out the knock sensor.
regards
how does it run when it stats. does it idle down to under 1000 rpms? can yo u drive it? if so does it fell like it has less power than it suppose too?
