Engine fuse keeps blowing?
Ocnaj
I have a 1989(1st gen) 4runner with a chevy 350 V8 and for some reason my engine fuse keeps blowing, and sometimes the starter doesn't turn over at all, not even a click or anything. I went and got the battery tested and it is ok so its not that. Could someone tell me why this is so?
A fuse blows when you have a short, or when the circuit it protects draws more current than the fuse is rated for. Start checking your wiring for a pinched/smashed wire, loose/corroded ground connection, etc.
Could the starter be going south and drawing more than it normally would? How many miles do you think are on the engine / starter / drive train?
I had a similar problem with a windshield wiper motor. Kept blowing fuses and eventually went completely out.
Mike in AR
Ocnaj said:
My starter and flywheel are brand new, could it be the starter relay? thanx for the help guys.
Some of the things on the Engine fuse are:
inst cluster, pwr windows, neutral strt sw, ECT computer, O/D indicator, B/U light sw, seat belts, haz flashers,
if you are also using the GM alternator it has a built in voltage regulator so you are going to blow the main fuse you need to unhook the toyota regulator or get an alternator without a voltage regulator
tobasko556
