engine lurching and skipping???
Tikka250
hi there. iv been a lurker for some time now and the information you kind folks have posted has helped me with many little projects and problems i have had with my t4r.
however this recent issue i am having is somewhat baffling.
today as i was driving i noticed a bit of a hiccup in my engine when going up a hill and passed it off as hitting a small bump. about 10 minutes later i noticed it again and this time knew something was wrong. after pulling over and checking for any fluid leaks or loose/frayed/bad wires i decided i was good enough to at least make it to a friends shop 2 miles away and this is where things realy got strange.
i was able to make it up to 80 kmph with no problems but then noticed that when i tried to accelerate it would not make power and would lurch much like hitting a small bump in the road, rpms would not go over 2grand.
my buddy suggested taking it out of overdrive and this seemed to help. i had no lurching or power issues until i had to slow for a truck to go by. i went to accelerate to normal speed and was faced with the same lack of power and this time the sensation like that of hitting rumble strips. if i accelerate slow this dosent happen.
i am at a loss as to where to start i have someone bringing a code reader over but with no check engine light im not optimistic that will turn anything up.
i am driving a 96 3.4L with a little over 300 000 km (186 411 miles). no check engine light fluids are all fine and full.
any help on where to start?
OK, so this may sound out in left field, BUT does it feel kinda like a stutter. If so, you may want to start by looking into plugs and wires.
Mine did a similar thing and after throwing money at the wrong theory, I found it was just needing plugs and wires.
yea its like a stutter preventing me from accelerating. just curious what wires needed to be fixed on yours?
ok thanks i will check that out. i was asking because due to an incident from a while back i have needed to replace one of my ground wires and thought that may be it.
When it happened to me I thought it was transmission related, but low-and-behold simple spark plugs.
BTW, be sure to buy OEM plugs. These trucks don't like aftermarket plugs.
ok awesome thanks for the tip. went out for a diagnostics drive with a buddy and we found it only does it when its warm and the clunking happens during gear changes. also a lot lower on power in general. hooked up his scanner and got nothing.
ghengiskhan
