I put 5 qts without a new oil filter.TRD04RUNNER said:It's 5.5 qt for the 4.0L v6 with a new filter
Larry said:Just be happy they poured the oil in the right hole.
tcpoob said:hmm, if it's only 5.5 qt, the stealer's svc dept cheated again - just had 1st oil chg done at (Woburn Foreign Motor/Toyota), fast lube. they chrg'd a little extra than advertised - invoice read about 6 quart as parts, maybe over 6 - i just couldn't make sense out of that invoice on the breakdown. the total w/ coupon is about $24 which wasn't bad but i thought i was surprised their indicated engine oil vol exceeded the total capacity that i remembered from the manual.
it's a v6 4wd 2005 sr5.
Larry said:You might want to work out changing your own oil. For some it's not possible but if you can it's worth the effort. It's not difficult and you may find that doing it yourself is worth the effort... and you'll be sure you got the right oil and poured it in the right hole. The process will get you under the hood to check things for yourself.
Two oil changes ago I discovered a nail in a tire. It looks ok, not sagging, but the pressure was 25psi when I keep them at 36psi. I'm glad I found it in my driveway and not out on the road somewhere.
