Entune - Possible To Remove Audio Sources?
vertwake
New member. Just picked up my 2014 Limited last weekend.
Anyone know how to remove audio sources from the options list? Example: I'd like to remove AM so when I'm cycling through sources it skips over that.
Is it possible?
No. If you program all the presets as FM or satellite stations you could just scroll through them instead.
New member. Just picked up my 2014 Limited last weekend. Anyone know how to remove audio sources from the options list? Example: I'd like to remove AM so when I'm cycling through sources it skips over that. Is it possible?
Hi vertwake,
I guess you mean like using the 'favorites' button on your tv's remote; you can 'Add' or 'Remove' the channels that you don't use?
Not too sure it works that way w/the HU's mode Options. Notice that when you unplug an ipod from the usb 2.0 port, you can still see the "Grayed-out" (unavailable) image of the word 'IPOD'? This file selection isn't removable but permanently written in the firmware program, and becomes available when this external device is connected. Perhaps someone here knows a way to do it but I don't think that option is available at this time. Rgds
I wish this were an option as I don't use pandora, iHeart, AM or XM, so let me skip them when using the steering wheel mode select button! The only thing I've been able to do is rearrange the FM and bluetooth to be sequential. Seems like a simple enough request and one of those things that shows that Toyota is not Apple when it comes to electronic to driver interfaces.
