Exhaust Quest
XCdoctaCX
Does anybody know what the most practical exhaust is for a 98 4runner? I'm looking for something to increase my mpgs and I have seen Borla and Magnaflow mostly and I am leaning towards the magnaflow but I'm not sure which one to get and where to find the best deal. Please reply. I need help.
I got an 18 inch magnaflow and I'm having it put on tomorrow. Just the muffler. I'll post a thread after I've used a couple tanks of gas to see if there are any MPG increases.
I'm partial to the 24" Magnaflow my friend has on his '00 Runner since it has a nice mellow sound at idle and a bit of a growl once you step on it but it's not obnoxious.
MPG increase will be negligible as it's more of a sound mod than anything else.
Strange. I've done a fair amount of research both company side and consumer and all point to an increase in mpgs whether it be big or only slight its still noticable. I talked to a guy in 4Wheel Parts (national off-road store) and he said that it should increase my mpgs and it did so for him. We'll just have to wait and see. I think I might just end up making it custom and just running a dual off one muffler or getting one of those cross overs. I just don't know where the best place to get the stuff is.
I had my muffler installed about a month ago and it has pretty much done nothing as far as MPG, or at least that I can tell.
Are you just replacing the muffler or the whole exhaust? If you just replace the muffler you may see gain some MPG but I doubt that it will even be noticeable to you. Some will tell you that they have gained MPG but I seriously doubt you will see much. I could see you gaining 1-2 MPG however if you replaced the mufffler, and had all the tubing re-done with mandrel bends and maybe 1/4" or 1/2" bigger.
I've got a relative who is a mechanic so I'm going to get him to help me bend the tubing and such so I can get a bigger flow rate etc. I guess I'll go with the flowmaster. Please excuse my ignorance but what is a madrel bend? I like your setup trd_. Mine is very similar to yours without the rims but much of the custom dents...ha.
So now I'm stuck between mufflers. I'm just going to chop the tubing off right behind the cat. and then attach the muffler right behind and then use the last 1.5 feet of existing tubing and go out the side underneath the back passenger door and do dual tips. I think it will look tight just a little worried about burning people. Now I'm stuck though between the Flowmaster Series 40 and the Flowtech Raptor...Which one? I want something a good sound to it just not raspy which is what the flowmaster appearently sounds like.
rxshu said:
I got about 30 more miles on a tank of gas when I put my Flowmaster on.
same here, i went from 300 miles a tank to around 330. and that is with basically new everything on the exhaust.
get a roof rack and you will see that extra MPG vanish :)
my advice is if you don't want loud dont get flowmaster, if you want some noise but nothing to much, i'd get the magnaflow.
How do you get 330?? I am lucky to get 300! My light comes on at 260! And I have the deckplate and flowmaster. Before those two mods I only got 200 before the light came on!
i think the 01-02 models get better gas mileage anyway. plus mine is only 2WD which helps out some and i do alot of highway driving so thats probably why. i haven't gotten 330 in a long time.
Mandrel bend keeps the uniformess of the tubing through the bend rather than distort the shape of the tubing... thus less restricted airflow.
Normal Bend
badbend.jpg~original
Mandrel Bend
good90.jpg~original
Also, have you listened to mufflers at all on 4Runners? IMO the flowmaster doesn't sound great on the 4Runner and their technology is actually outdated. I think the magnaflows have a much better sound but again this is only my opinion.
Thanks a lot for that post. I will definitly be going with the series 40. I think instead of the dual though i'll have it come out the side either behind the back passenger door or between the passenger doors and then do tips.
When you guys post MPG numbers remember to throw in the facts like 2wd,highway or city since just throwing numbers out there tends to confuse others into thinking they may be having issues or thinking they will get the same gains.
30 more miles a tank is realistic but if it's all city driving that gain might not be as prevalant.
My mom see about 320 miles a tank with all highway and she's 4wd but city driving she gets about maybe 280 and with an exhaust upgrade I doubt she's going to see too many more miles to those numbers but it might be a little gain.
Real world numbers with 4wd 3rd gens (even with intake and exhaust mods) are 16-19 in the city and 22-23 on the highway.
Some will see more but it's usually with given special circumstances as seeing almost all flat ground or benefiting from a tailwind,etc.
Adding dual exhaust will hamper horespower and MPG gains since it's extra weight will negate it and in most states it's illegal to re-rout the exhaust in front of the doors if it originally exited out the back plus it can be a hassle for rear passengers plus rerouting it under the frame on the sides is asking for trouble if you do anything off road.
I'm doing it in front of the door so I don't have to buy an entirely new system and not dual. The armor that I have on the car is actually lower than where the exhaust will exit so that is not an issue because if the sys. gets scrapped off where it will be, then it would have happened in the back to. As for the legality...I'll ask around. The side exit was my uncle's (who is a professional and award winning mechanic) idea so I see little reason why he wouldn't be aware of the law. As for dual exhaust hampering mpgs because of weight...I'm not so sure. Everything I've encountered points to a higher horsepower because of the flow physics behind them. Why would high performance sports cars like audis be equipped with them if they hampered the car?
MMJR_T4R
