Extended Rear End Links for Sway Bar
ARC
Trying to find replacement links to use with my 8 wraps. Can anyone point me in the right direction to get some or let me know about how long they should be? Quick disconnects would be cool but not required.
Thanks!
With a typical 3" rear lift you could use anywhere from an extra 1"-2". This will get you sway bar back to it's intended position. I make heavy duty links if you're interested.
Sway Bar Links
I have seen your links and like what I see, but what is your current lead time?
About 10 days to ship. I just finished a large group buy that I'm hoping to have completed by the end of next week at the latest.
Cool I'll keep you in mind. Wish I didn't have to save the last of my budget for this rear axle job. Hopefully I get my take off tires sold soon.
Sway Bar Links
I have a set of Mike's links on the front and rear (and no, he isn't paying me to say this.) The links and Mike are top notch! Good luck.
What do you recommend for securing the bar when using disconnects?
I'm not running any fronts on mine. With the front the sway bar is connected to the frame. You can secure it up with a small bungee. Or, if your bushings are a bad as mine they'll hold it in place. With the front I've disconnected one side and run it, and I've disconnected both side a run it. I just let the sway bar be.
