WheelinGypsy
So I went to install a new radio in my Girlfriends 1997 V6 4Runner, and I discovered that the previous owner had cut apart the factory radio wiring to wire in a new stereo instead of buying the plug to plug into the factory wiring.
After spending a few hours trying to decipher what wire from the main truck stereo wiring should attach to the stereo, I was unable to power up the radio from the wiring... I manually connected the radio up to the Cigarette Lighter wiring to see if I could get the radio to turn on, which it did.
I ran out of time and had to put the center console and bezel back on without the new radio working, and the next day all of the Power Locks, The High-Beam switch (Not the momentary), and the reading light by the rear-view window all stopped working...
I have checked all the fuses and I cannot find what the problem is...
I suspect that I may have shorted out a wire while trying to install the radio, but what wire(s) would have caused all these electrical issues??
Thank you for your time...
