F/S Lifted Black 1999 4Runner Highlander - Va Beach - $7800
hearno
Senior Member
SOLD Lifted Black 1999 4Runner Highlander - Va Beach - $7500
For sale is a clean, black, 4wd Highlander edition 4Runner. The current mileage is 148.XXX. It was lifted last March and Bilstein 5100s with Old Man Emu coils, not a spacer lift. The truck has racked up around 4000 miles since the lift. New tires were also installed at that time, 33 inch Nitto Trail Grappler mud tires. 285/75 R16. The truck has an AFE cold air intake and new Borla exhaust, the exhaust gives a little extra tone but doesn't drone or make enough noise to be a bother. Spidertrax 1 inch spacers were added to the truck to give the factory rims a little more poke and help the tires clear. Only known issues: sunroof should probably stay closed, it might not shut if you open it. Driver side inboard cv boot is open, just happened. CEL for rear 02 sensor occasionally, currently off.
Timing belt and water pump were replaced @ 119 miles, so just under 30k miles ago, not due for a long while. A/C works great and obviously the heat does as well. No other issues with this truck.
*****I get a lot of questions about this and rightfully so... RUST. The underside of this truck is clean, very clean. See attached pictures. Clean VA title in hand, open to reasonable offers, let's make a deal.
PICS: https://norfolk.craigslist.org/cto/6016696301.html
