Factory Frame Undercoating
raKnizek
Member
Does anyone know if Toyota applied any sort of undercoating to the actual frame rails on the 3rd gen? I went to go do a little degreasing yesterday and noticed that I was able to scrape off a thin layer of material on top of the painted surface using a plastic wedge. I cant decide if its dirt or 20 year old rubber coating.
The reason I am doubting it is I applied Fluid Film 4 years ago. Haven't applied it since but also have not driven in the winter since that one year. I know I went pretty heavy with the stuff so maybe it is just a result of that.
2000 SR5 for reference. Thanks!
Some Toyota dealerships offer this on new vehicles, I now advise against it, it's like a rock guard/tar, what a mess and really no help accept for abration, better to oil it regularly. And who knows who sprayed it that day or if they hit any areas that it would be effective..
Mine was undercoated at the dealer, it just traps salt and moisture and causes rust so I scraped it off and oil the frame
Thanks for the insight. I've seen horrible things happen to vehicles that were undercoated from new. Once there is a hole it effectively turns into a rubber glove that keeps all the dirt, salt and moisture cozy to the frame.
Looks like my fluid film application stuck around longer than I expected! Which also explains why its not very consistent at this point. Appreciate the reassurance.
Mostly if they are coated when new. They used to drill the rockers and doors in the 80s. Mine was just the frame. Did it help maybe some. However, the frame still rooted out in places. I removed it off my frame when I fixed it. :)
Sent from my SM-J337V using Tapatalk
Laredotx
