Factory JBL sub enclosure help
GX4SEVEND
So from the searching I’ve done the enclosure part number is 86150-35080. It’s $168 from Toyota but after going to the dealer to ask about availability and their price local, not online, they said that part number is for a 2017 or 2018 to 2020. I don’t remember what they said but they gave me a different part number for mine, which is a 2014 SR5. That part number is 86150-0W120. However, that’s listed at $440 online and $608 locally.
So my question is why such a huge difference?
I wanted to go this route because it saves me a ton of cargo space and I thought it would be the simplest way to do it without paying someone to fab an enclosure. Plus I’ve seen people running JL and Kicker 8” subs with great results.
Any help is appreciated or if someone knows if the cheaper box listed actually works in all years that would be awesome.
it looks like this part number 86150-35080 is only for the 18-20 runners.
Toyota4Runner2020Limited, Nightshade, SR5, SR5 Premium, TRD Off-Road, TRD Off-Road Premium, TRD Pro, Venture4.0L V6 - Gas
Toyota4Runner2019Limited, SR5, SR5 Premium, TRD Off-Road, TRD Off-Road Premium, TRD Pro4.0L V6 - Gas
Toyota4Runner2018Limited, SR5, SR5 Premium, TRD Off-Road, TRD Off-Road Premium, TRD Pro4.0L V6 - Gas
86150-0W120 is for 14-17
Toyota4Runner2017Limited, SR5, TRD Off-Road, TRD Pro4.0L V6 - Gas
Toyota4Runner2016Limited, SR5, TRD Pro, Trail4.0L V6 - Gas
Toyota4Runner2015Limited, SR5, TRD Pro, Trail4.0L V6 - Gas
Toyota4Runner2014Limited, SR5, Trail4.0L V6 - Gas
other then that, not really sure what changed. but who knows, it may still fit. perhaps a plug and logo changed?
https://www.youtube.com/watch?v=6a9bJhU2Aoo
I ddi a quick google search and it looks like your part number is right. Check out this video
That’s the video that started my research. However in the first 5 seconds he mentions its a 2018. Which is the cheaper part number I listed. I have a 2014 which has a different part number and is 2.5 times the price.
I was hoping someone would know if the cheaper enclosure works. Or what exactly they changed after 2014 to make it so much cheaper
Yeah I’m wondering how much actually changed. Or if my year came with the sub and amp as well and that’s why it’s so much more.
Just don’t want to take a $170 gamble and have it not work
Your first link goes to the boards terms and conditions.
Second link doesn’t work at all.
His is a 2017 which is the same part number as mine, the more expensive one, so I sent him a PM and I’m waiting to hear what he says.
Ok a little update ......
Toyota said the 86150-0W120 was used from August 2009-April 2017.
Then in May it switched to the 86150-35080 part number.
Unfortunately it didn’t list the reason for the change or what actually changed on the enclosure itself. Could have been a change in manufacturer who knows
I know this isn't a solid answer, but I highly doubt anything changed that matters to someone putting a aftermarket sub in. The mounts should all be the same.
Maybe the wire connection is different or a clip was added somewhere... nothing that would matter for an aftermarket install.
Ordering it is easy. There’s one somewhat local and can have it next day.
The issue is the model number that “fits” according to Toyota is $444 online and $608 and the dealer.
The cheaper one that’s for a 2017-2020 is only $168. That’s a huge difference. I doubt anything changed either but I don’t want to waste $170 to figure it out or spend $444 on it either. By the time you add an 8w3 you might as well buy the stealth box from JL.
I guess I will try a local yard to see if they have one or keep watching eBay.
86150-0W120 the part I ordered too. Pretty sure they just recently updated the specs for just 18-20. I want to say it had the older years listed before but idk, I got a 19. But Ifyou look at the rest of us that have factory enclosures, like blackack, we all got same part#.
Maybe take out the rear quarter and see what your opening looks like. If the same your good to go
86150-0W120 is the part number that was on the sticker on my enclosure. I have provided this part number to numerous people and they were able to contact their Toyota Parts department with this part number and they were able to order the enclosure without the speaker
Thats probably what he difference is, 86150-0W120 is just for the enclosure and the other part number is the complete unit. I remember when looking for the factory enclosure years ago it was $400+ so I gave up the idea.
JL doesnt make a stealthbox for us, and even if they did it would be around $800. Even their enclosed subs are expensive at $400+ and then you lose cargo space.
If you want to save money the Dayton HO 8" is $120 and its extremely similar to the Jl 8" W3. I dont know if the Dayton will fit in the factory enclosure (mounting depth is .33" deeper).It also needs .5 cf vs .3 on the JL, I dont know how much space is in the factory enclosure. I have a Dayton 10" in a custom enclosure in the same area and it is very impressive.
Just buy the 86150-0W120, we promise it will work :thumb3:
Yeah the 0W120 will work for sure I just can’t find it for less than $438 from Toyota. That’s why the other Toyota part number I wanted to try at only $168.
I will try to see if a local yard has one or keep watching eBay. It’s just a lot to spend on an enclosure when after 2016 they switched part numbers and dramatically dropped the price
If one adds the factory sub, can the factory amp be installed also? Would it be worth it. Is the harness available for plug and play? I've been looking at the Alpine under seat amp/sub kit, or tocotunes set up.
I don’t think the cost is worth it. Factory amp isn’t great and it’s over $400 from the dealer. Taco tunes have plug and play harnesses for adding an amp and look super easy to do
Plug and play through taco tunes is $35. No possible way that’s worth $500 even if the bracket was made of titanium
Use the to buy a set of focal fronts and another amp to run those and you’ll be way happier
AndiGarage
