Fightman's Build Thread
Sweet man! How do you high-5 someone over the net? Looks amazing! I'm so going this route, thanks for the write up and ride description, how much did it cost you for the front assy if you don't mind me asking and got some part numbers lol or did i miss that bit?
The front assemblies were pricy for me, as I live in the Great white Canadian North, and had to pay a ridiculous amount for the shipping. It cost me about $160.00 for the 2 struts, plus another $140.00 for shipping, and then another $25.00 or so for the Customs fees. The shipping is what killed me. You guys have it made States side!
As for part numbers: I had them on a PM Blcktpgr sent me, but ended up deleting the message. You may be able to get them from him. I ended up finding out that the part numbers matched the Coils that went on a 2002 Tundra TRD Access Cab, so I just looked for some on E-bay and bought some from Nordstrom's Automotive Inc. Shipping was quick, and the quality was great!
Got some 99+ Headlight Assemblies!!
Here's a shot of the OLD VS the NEW:
P1110374.jpg~original
The light that spawned my wanting new lenses.....notice the nice chip to the right....
P1110373.jpg~original
The head mechanic putting the last light in:
P1110376.jpg~original
Oh....by the way....these are just teaser pics! Gotta wait till tomorrow to post the pics of the lights installed, as it was dark when I finished. ;)
I think I've just been convinced to make the switch over myself. Where abouts did you get your lights? Looks nice. :banana:
whoa nice. glad u took off those headlight covers! what happened to the homemade roof rack???
Thanks man! Those light covers were only supposed to be a temporary fix to cover up the chip.....5 years later......ha ha ha!
As for the roof rack, it's in storage till next Spring. I'm planning on tinkering with it this winter, change up a few things, and actually wire up the lights that are mounted on the damn thing....never did do that!
Diff Breather Mod
So this is a mod I've been procrastinating to do. But today, while waiting for paint to dry, I decided to go ahead an get -R- dun!
First, I had to locate the original diff breather:
P1110569.jpg~original
Once I loosened it off with some WD40 and a ratchet Wrench, I removed the old breather and then installed the Union fitting:
P1110570.jpg~original
Once I was done with that, I moved on top by the Gas filler neck. I drilled a hole through the rubber gasket using my biggest bit and a drill. Once that was done, I fished some Fuel Line hose through the hole. I noticed that I couldn't find the other end of the hose, so I removed the Gas filler neck shield inside the inner fender, located the end of the hose, and then fished it through along with the gas filler neck.
P1110574.jpg~original
P1110579.jpg~original
Then I ran the fuel line to the Union fitting and secured it with a hose clamp. I then zip tied the fuel line to the Gas Filler neck, but leaving some slack to permit articulation:
P1110581.jpg~original
P1110580.jpg~original
P1110573.jpg~original
Once I was done below, I moved back on top, and added the new breather plug. I used another hose clamp to secure the fuel line it, and then tucked it in.
P1110583.jpg~original
Overall, it didn't take me much time to complete this mod. The only trouble I really had, was washing all the grease from under my truck off my hands!
That....is one greasy underside, but I guess you have that for the purpose of rust proofing?
I did this same mod months back, but to this day I still haven't been able to put it to the test. I had that one chance but crossing a fairly fast stream current got me backing out.:D.
Glad you finally found the time to do it...next?
You guessed right man. The winters here, can be horrible. The City uses road salt liberally, and trucks around here don't look good for long! My rig already had some corrosion from the 1st 6 years of it's life with the P.O. He never rust proofed it, and the underside had quite a bit of Orange. I've been spraying it anually since I got it, and it seems like the rust has been kept at bay.........
As far as what's next: I'm still finishing up my lower valance to put the driving lights in, and I'm working on saving some money for my Full sized spare......
Safari Light Bar....NO MORE!
So I decided to get rid of my Safari Light bar, and gain some ground clearance. I ended up making up some Light pods out of Margerine containers, and then mounting them into the Lower Plastic Valance to give them a more "Stock" look:
P1110603.jpg~original
Here's some pics of the process:
P1110511.jpg~original
P1110563.jpg~original
P1110594.jpg~original
P1110601.jpg~original
And another shot of the finished product:
P1110602.jpg~original
Added a "4Runner" badge to the rear hatch to change up the look of the stock badging!
Well, after seeing it photoshopped, I decided to do some E-Bay shopping! Found the 4Runner emblem and also a "Toyota" emblem for approx. $15.00 shipped.
P1110707.jpg~original
Don't mind the dirt on my truck, it's winter here, cold as hell, and I'm not washing it till spring!
Just an FYI, I did clean off a spot to install the emblem! I was raised in the country, but I ain't no hillbilly! ha ha ha!
I just remembered I upgraded my horns last year! I got mine from Princess Auto, it's like a Tractor supply store....with all kinds of stuff for sale!
This pic, is for demonstration purposes only, It's got the low tone horn pictured, I used 2 high tone horns.
1zlt3t4.png~original
[/quote]
I snapped these pics when I did my headlight conversion
P1110381.jpg~original
P1110379.jpg~original
I ended up getting 2 high pitch horns though, but still better than the stock setup!
Here's a pic of her on the last run of the season......
P1110625.jpg~original
Then.....this happened.....
P1110630.jpg~original
Now I'm searching for a deal on another bumper. I was thinking of upgrading to the 99+ bumper, then thought of using a Tacoma bumper, and now I'm thinking of just replacing it with another 98 bumper! ha ha! Still not entirely sure yet.......
You have an awesome truck. Nice job keeping it clean and trying to keep the wallet from evaporating haha.
Keep up the good work man. BTW I feel your pain with the Canadian snow and liberal salt usage. We have a full week of snow that has been forecast for us. Good times.
Thanks for the comments man! It definately is a constant battle of the rust! Luckily for me, I've been able to keep it a bay.....
What happened to your bull bar? Thats why they make them :thumb3:
Anyway I really Like your rig, looks wide as hell with your suspension setup.
I took it off about a week before "the incident"! ha ha ha! I posted a poll, asking everyone on here, whether I should keep it, or lose it......most said lose it! So I decided to try something different, took off the light bar, and built in my driving lights into the lower valance. I'm not going to blame the masses for my damaged bumper, but the funny thing is, if the light bar were still there, it probably would have saved my bumper! he he he! Either way, I'm planning on replacing it in the next couple of months, and going to try to do a better job at installing the driving lights! I'm planning on grafting the lights into the valance, and then maybe plasti-dip the whole assembly! (leaving the chrome bumper alone though, I like the chrome bumper on my rig)
DJNutshell
