Final check with you pros before buying wheels
flipmode
I've searched, but just need your expertise before clicking checkout button.
Buying 17x8, 0mm offset, 4.5"bs with 265/65/17. These will fit stock 4th gen, right?
Thanks a lot!
They should fit. You might get a small bit of rubbing on the front fender liner due to the offset, which is similar to spidertrax on stock wheels. Mine rubbed a tiny bit on one side when I added the spidertrax. It is easily fixed by moving the liner forward a bit. Make sure they are the right bolt pattern and hub bore diameter.
thanks, bolt pattern is 6 on 5.5, and bore is 108mm
7ron
