[email protected]
Ten minutes at the parts house,30 minutes on the truck and no more cussing,no more fussing,and best of all no more shit forsaken CLICKIN!!!!!!!GREAT FIX.
EXACTLY what's clicking and where?...started doing the ole one click no start.
Because Toyota Parts are bullet-proof. The problem lies in the wiring that Toyota did wrong AT THE FACTORY.Replaced the starter on the the trail, nothing
How does the cranking feel/sound?... You can hear the starter trying to turn and engage. Jumping the starter signal wire straight to the battery gives same results .
So I’ve got a good for you guys.
I did the final fix years ago, no issues since until....
Last run I went on out of no where motor wouldn’t start, started doing the ole one click no start.
During this trip my clutch was going out
So got home replaced clutch, new flywheel, new master cylinder, new starter, still nothing
Engine turns over by hand and can start it by bump starting it. I have 12-13 volts at the battery, 12 volts at the positive leading into the starter, 12 volts at the solenoid when cranking.
When I replaced the flywheel it has some good wear and small chunks broken off the teeth. So wth is going here. My initial though was thought the clutch was grabbing, giving just enough resistance that the starter didn’t have the power to turn the motor. You can hear the starter trying to turn and engage. Jumping the starter signal wire straight to the battery gives same results
Any thoughts what to check next? I’m losing my mind over it
[MENTION=80771]RAD4Runner[/MENTION]
Can you put up a diagram of the wiring? Or pictures of the connections at the starter?
Trying to do this now.
thank you
Nick
