Finally got around to upgrading the audio..
emmwhat
My truck came with the JBL synthesis, but I wanted to make it sound mo betta.
Parts List:
Alpine INE-S920HD - Head Unit
Alpine KTP-445U - Speaker Amp
Rockford Fosgate PBR500X1 - Sub Amp
Polk MM840-DVC - Sub
Infinity 693.7i - 6x9" Front Door Speakers
Infinity 6012i - 6 1/2" Rear Door Speakers
Polk DXi350 - 3 1/2" Front Door Tweeters / Rear Cargo Tweeters
Dash "kit" PZ365-35904 from Toyotapartszone.com
Right Side Steering Wheel Controls 84244-35030-B0
Right Side Steering Wheel Control Ribbon Cable 84204-58010
Axxess ASWC-1 - Steering Wheel Control Adapter
Sony CCD Rear View Camera (eBay)
Parking Brake Bypass (Alpine cannot just be grounded out)
Metra Antenna Y-adapter
Antenna Adapter
And power wire kit / Fuse and holder / 3 sets of Rockford RCA cables / Speaker wire from sub amp to sub / Solder / Bandaids / Beer
This job was a lot, but I just did one - two steps a day and took my time, it turned out great.
New sub
1.jpg~original
New sub amp (the wiring is different now, this is when I had it inline with the factory amp before I decided to upgrade the headunit)
2.jpg~original
Old nasty sub
3.jpg~original
This little magnetic light is AWESOME
4.jpg~original
These wires are shielded, no interference
5.jpg~original
I saw a lot of people asking where to mount crossovers, this worked perfect
6.jpg~original
Replaced the front door tweeters and rear cargo speakers with these; I need to go back and put resistors inline, they are a little TOO loud (marine rated for when windows are down)
7.jpg~original
Front speaks
8.jpg~original
Cargo tweets (had to rewire both of these, apparently they're wired together, so to separate left from right, you need to run new wires)
9.jpg~original
Alpine and Urbanrunner trim piece
10.jpg~original
No right side controls
11.jpg~original
More buttons!
12.jpg~original
Back up camera (sorry, it was getting late)
13.jpg~original
Tweeter brackets (take the bracket off the door, mount the speaker in it, then reattach to door, it works 100x better than trying to make the speaker fit in the bracket while attached to the door, the bracket needs to bend a little)
14.jpg~original
Better than JBL
15.jpg~original
Perfect fit, no clearance problem at all
16.jpg~original
Finished door
17.jpg~original
Finished sub / amps
18.jpg~original
The sub amp is kind of hidden
19.jpg~original
I drilled the plastic welds off this panel so that I can put it on and take it off to adjust amp settings without taking the whole cargo area apart, I figured it would rattle a little since it's just clipped in and not "welded" in, but there's no rattle at all!
20.jpg~original
The Infinity speaker part numbers I used are discontinued, I had them laying around from a previous vehicle.
I'm very happy with this upgrade, the sub sounds amazing for being a tiny 8", I'm really impressed.
Others things I've done since I got my truck about 5 months ago:
Remote start
K&N Drop in filter
MAF cleaning
Seafoam (fuel system and vacuum line)
Removed Hydrocarbon filter
New Denso Iridium plugs
EBC Greenstuff brakes on all 4 corners
Turned front rotors
Replaced passenger front caliper
Originally had installed Parrot MKi-9100 before I did the new headunit
New front Bosch o2 sensors
New OEM PCV valve
Removed 3rd exhaust cat
Removed rear exhaust resonator
Angled rear exhaust tip to the right (no more in cabin stench with rear window down)
Things I still need to do:
Get / retrofit HID projectors
Add seat heating elements under cloth (front seats)
Get new wheels, mine leak from corrosion around the bead, I think I want FJ wheels
Leveling kit for the front
Replace xreas with some new shocks (I have about 104k miles)
Take it camping, on the beach, and over some rocks!
That is all..
Wow sounds like you got a lot done.
System looks sweet, I'm a little confused though. How are the speakers in the cargo area powered? Also do the right side buttons work well with the alpine HU?
I'm not sure why the photos didn't load, but they're all here https://www.icloud.com/photostream/#A35qXGF1G8IZyO
You need to find a link to use that ends in .jpg probably. I'm not sure if you can share from iCloud on forums and such. The links you provided will only show pictures if make them links and we click the links.
It was a lot! haha, I've been putting it off for a while, but looking at ~$1,500 worth of parts just sitting there everyday finally got to me.
The cargo speakers are originally run in parallel with each other, and it's only 1 true channel, not stereo. I have the them set up to run parallel with the left and right rear speakers, like the left rear output from my amp goes to both the left rear door and the left rear cargo.
Alpine could really use an update on their phone controls; the "pick up" button will answer an incoming call, but you can't use it to make a call or redial, the "hang up" button works, it hangs up the call, doesn't do anything when out of a call. This head unit doesn't support "push to talk" or siri, so the 3rd button didn't do anything, but I remapped it to be a mute button, works fine for that.
I've always added bluetooth to my cars, I've used quite a few different modules, and they've all be able to access siri somehow, I'm not sure why this one won't, I've updated the software, hopefully they'll fix that soon. I'm not complaining, it sounds and works great!
Looks good, I used those same Fosgate RCAs for my install.
Thanks! Yeah I've used all different RCAs over the years, but Rockford have always seem to given me the least interference (and I know you're not supposed to run RCAs along with the power cable, but these are shielded so well that it doesn't matter)
Nice job. did you have to dent the doors at all to get the 3.5's to fit?
also, did you ditch the center channel speaker?
also, also, since you're in md...
http://www.toyota-4runner.org/off-roading/143217-dc-va-md-wheeling-trips.html
and now :focus:
The 3.5's that I got fit perfect on the doors, no denting at all, and they press against the metal so they don't vibrate or anything like that, I got really lucky when I ordered those. Although in the rear cargo area, I had to dent the metal a little to get them to fit.
I DID ditch the center speaker, I was going to use the front speaker outputs on the head unit and hook it up (and use the RCAs for all the other speakers) but I decided against it, maybe later on I'll hook it up, I do have plenty of fill with those new "tweeters" though so I don't really see a need, plus that's where my GPS antenna is mounted now.
Thanks for the link! I'm going to check that out right..... now
Lol anytime. I had a 3.5" speaker in the CC but I ditched it since my new radio doesn't have a surround function, it was really quiet. But I'm thinking about adding it to the rear cargo area to replace those two for a fuller tailgating experience...
Nice job! It's good to see you could get the right side steering wheel switches to work. I had the switches from previous installs of OEM units, but when I went aftermarket, I didn't have any luck with them, so I removed them. I started off with an Alpine, then followed up with a couple Kenwoods.
How do you like the small amps? Have you experienced any problems (overheating) with the Alpine amp mounted behind the panel? I did the same thing - made the speaker panel so I can remove that portion without dismantling the whole cargo compartment. I've been itching to get a couple of these little amps. Very cool just how small they have made them, as long as they last, and sound good.
DJNutshell
