Finally got my REVOS installed
Also, what size did you put on. If you went with the 70s, that will add to the loss!
Koz
Koz said:
The mileage on the REVOs will fluctuate allot depending on what pressure you are using. I found that 40 psi was best.
Koz
This is true , I forgot Koz told me about that and actually the gas milage was better and did not sacrifice anything.
Hi Koz, I did go with the 70's..I will try 40 psi...makes sense as that would reduce the rolling resistance...I sure hope they are not set at 40 psi right now!! LOL
I also felt my traction was increased in the snow at 40 psi also. (Weird but it was) I aired down during the winter and Koz said to bring it back up and it did help quite a bit.
Also my comment made in my first post about muddy , slippery conditions is a normal thing for an all terrain tire. I didn't expect anything to be any better there.
Ok---I run my Revos at 36-38psi, and during the summer I get consistantly 21+ mpg's. Dont know what I would get the the stock Dunflops---I got rid of them after 5K miles. During the winter, with the winter blend gas around here, I am still getting 18mpg's consistantly.
FYI-This is based on actually calculations, not relying on the mpg gauge in the truck which is always 1.5-2 mpgs high.
I just checked and my tires are at 32-33psi...I am filling them to 40 psi and I will let you guys know if there are any changes in the mpg's
HEY SHAUN...your link to see your pics and fourwheelin isnt good any more!
I think this is relevant but off topic, if possible.
Tire pressure is so tricky. If you have a 44psi P265/70/17 Revo or even the 80-psi
As far as knowing what is the best air pressure to achieve the best handling, there is an old way to get pretty good results. Make sure the tires are up to operating temp, by driving the vehicle a couple miles. Adjust the air pressure in all 4 tires to OEM recommended pressure. Take a piece of white chalk and color a 3
hmmm...KOZ is that what you did to get 40 psi? I was hoping I could just use your results! LOL....anyways I just put 40 psi in the revo's so we will see what happens
No, the process is for handling and longevity, 40 psi is for gas mileage.
Koz
Just checked my pressure---a little low which would account for the decrease in gas mileage. Just topped them off at 38psi.
FYI--fixed the link for my pictures!
I don't mind the ride at 40 at all , yes you feel a little more on a rough road . I'm running P metric tires so they have more give than the one's (I think) Koz has . I preferably want to go with a "C" rated next time , and they are not available in the Revos.
I sure do see al lot of them around here on trucks mostly and probably the "E" heavy duty ones. I'm always checking out who's running what when I see whatever kind of truck at the Farm store.
I hate it when I'm doing that and the truck owner comes out....lol.
I just came back from 2 1/2 hours on HIGHWAY only....I averaged between 59 and 68 mph with the majority of time at 68 mph...probably 2 hours at 68mph. I got exactly 17.79 mpg with my revos at 40 psi. The best I got was 17.3 when the revos were 32psi. The ride at 32 psi was much softer though. I think I will go to 36-38 psi for slightly better ride than 40 psi...at 40 it is pretty stiff. I have the passenger not LT revos
That still sounds a good bit lower than the Dunlops. :confused: Were Dunlop MPG calcs with summer or winter gas blend? Did you use a correction factor on the odometer reading for the taller tires?
I know with my stock 265/65/17's (Cross-terrains) my GPS says the speedo is dead on but the odometer 'under-reports' by 3%. If mine is 3% under yours must be way under, possibily 7-8%. Next time you're on the interstate check it aganst 2 or 3 of the little green mile markers. If you're on for 10 miles even better; just clear a tripmeter as you pass one and compare the tripmeter to 10 mile markers' distance. :cheers:
I use TWO gps!!! I have a garmin c 580 and a tomtom 920!!
The speed I am posting is from the GPS NOT the speedometer!!
I think the difference is about 3.5%. I am REALLY dissapointed by the mileage...I drive like an OLD MAN...I have 5500 miles on the truck and I think all the gas around here is winter blend still...it was 33 degrees this morning. I bought the truck this February 7th so all calculations were done during the winter...I drove from Florida to PA with 500 miles on truck and averaged 19.5mpg with the dunlops at each fill up untill I hit snow in PA and then it dropped to 18-18.5. I lowered the air pressure to 37-38psi. rides seems a little better. I have only GOTTEN on the throttle 3 times since I have owned this truck...THAT IS IT...UGH! I think upsizing was a mistake for me even though I love the look! Heck my friend has a shelby GT500 with 500 horsepower and as long as he doesnt get on it he does 20mpg!
HMMM...so you mean the odometer is reporting less miles because of the larger tires so I would be getting approx 7-8% better mileage? That would put me around 19mpg?? 17.79 plus 7% equals 19??
They way I was thinking about it as follows: 300 tripmeter miles/16.9gallons = 17.75mpg.
Assuming you got 5% odometer error with the bigger tires and you have the same 3% I have, then
yes with bigger tires you actually travel further than the odo reads . I don't know about %'s though.
I have a little better news now! I checked my odo compared to GPS and I am at a 5% difference. Odo reads 9.5 miles and GPS says 10 miles. So 17.79 plus 5% = 18.68mpg...not great but better than 17.79
Jesse1
