Finally started my SS 1.3 install!
Skidmarcx
Finished my SS 1.3 install!
Haven't come across any threads with this system in particular, so I figured I'd make one. To start off I can't say enough good things about the service and product that Steve provides... great guy that has specific answers to specific questions about these rigs... Since Bilstein has a huge national back order for the their Tundra 5100s I chose to purchase RadFlo 2.0 coilovers with reservoirs... it was more money, but I think it's well worth it.
For reference 1996-2002 - System 1.3 [1.3] - $1,640.00 : Sonoran Steel, Sonoran Steel Custom Metal Fabrication L.L.C. Custom Toyota Truck Parts and 1995 ? 2002 2.0? Front Coil-Over Kit
Measurements from hub-body (not including 1" bodylift) with my sub/enclosure, hi-lift, factory spare, and hitch
Rear 24.5" on both sides
Front R 22.75" L 22.5"
I'm gonna let the springs settle before I do any further adjustments
The RadFlos are well built to state the obvious... They use spherical joints on both ends for smooth articulation and as you can see the remote reservoirs have plenty of hose for mounting. However, they did not come with anything to mount the reservoirs, so until I find a better solution I used 2" pipe clamps. These are different rear shocks than what most people use... the 5160 is valved for a coil spring and paired with a specific year LC front spring according to Steve... only drawback being is that you have to drill out the upper shock mount from 11/16" to 15/16" to accept the thicker top stud and bushing... not that hard to do I think it took me 10 minutes with a UniBit. Steve does provide you with genuine Toyota parts where possible (bushings, springs, washers, etc) which I like personally.
After doing some driving and breaking in the equipment I'm amazed at how well the RadFlos control the front end... It doesn't exactly match the feel of the rear since the LC springs are so soft, but I can't imagine it gets much better than this for the money. I think this setup actually does fairly well on pavement with the sway bars removed... The front end seems to keep the truck stable. I might throw the rear back on, but I'm gonna ride around for a few days to see how I like it in comparison to the OME setup without sway bars. I run through some of these trails fairly fast and not once did I feel the shocks lose their control. I thought OME did well, but these RadFlos keep the front end planted much better. I highly suggest getting the extended rear bump stops though because the rear setup is super soft... you will bottom this suspension out!
Here are the goodies...
Drilling out the upper mount
And... porn
Lookin' good!
I had a hell of a time finding my front Bilstein 5100s and then when I finally did, I couldn't find the rears. :redbrick: Fortunately mine should be in stock next week.
Lookin' good!
Thanks... Sucks having to wait, but it is what it is... I was going to wait until I had everything before I installed... I just couldn't help myself though haha
Ha yeah. I'm dying to put my front lift on but I would hate to have my front 2" higher than the back for couple of weeks. I had a '94 SR5 that was saggy in the back and I hated the angle of it.
*UPDATE*
Bilstein taking forever, so I decided to go with RadFlo 2.0 coilovers with reservoirs... I gotta say I think I made the right choice they're sexy... Will be installing today, so I'll update main post for anyone interested in this setup
They aren't terrible... A bit more than I wanted to spend, but I think it'll be worth it and better match the performance of the rear shocks versus tundra billies
No I understand, they look sexy. All my car builds have always been on budgets so I never get the pretty stuff, but I always research and get whats needed to keep up with everyone.
Dam your combo is going to be sick, how much did the rads cost?
Thanks man... I got a bit of a discount from Steve due to the long back order on the Tundra billies... It was very nice of him since it wasn't necessary... I'd rather keep it confidential... No offense
Got em in today I can't wait to hit some trails! I'm gonna let the springs settle and reset the front height... I'll update the initial post with measurements and reviews
Got the chance to dish out a beating on the RadFlos... I ran a mountain side trail at Four Peaks yesterday it was full of rock roads that we throttled through. The front end stayed much more planted in comparison to my old OME setup... I felt like the front end jounced too much with the 881s... Even going over obstacles it seemed smoother... I got to check the clearance between the tires and reservoirs and all is well during full turn situations.
[MENTION=1795]sschaefer3[/MENTION] if you wanna add any info
do you know what weight(s) spring is offered on the radflo coilovers?
Its a little blurry but you can make out the code on the Eibach spring.
Heres how to break down the markings on Eibachs. In this case 1400.250.0600S
1400=14" Spring Length
250=2.5" Coil
0600=LB's
S= Color Code
Keep note of these because you can actually swap out to different springs if you ever desired to tune the rate and valving of the shock. Most of us wont be desert racers and the out of the box setups are good for the average joe. But if you ever wanted to venture into tuning the shocks, these are some of the numbers you will need as a baseline.
AndiGarage
