Finally started my SS 1.3 install!
Its a little blurry but you can make out the code on the Eibach spring.
Heres how to break down the markings on Eibachs. In this case 1400.250.0600S
1400=14" Spring Length
250=2.5" Coil
0600=LB's
S= Color Code
Keep note of these because you can actually swap out to different springs if you ever desired to tune the rate and valving of the shock. Most of us wont be desert racers and the out of the box setups are good for the average joe. But if you ever wanted to venture into tuning the shocks, these are some of the numbers you will need as a baseline.
Thanks for clarifying... So what I have then is a 600lb/in
