First gen sunroof seal broken
SomeDay
Hi guys,
the sunroof seal of my T4R's broken, the one around the glass.
Do you know where I can get a replacement?
Thanks.
ie Toyota Parts Deal
Code and fuel system help needed
I have a 1900 4runner sr5 5 speed and it has a check engine lite and it flashes 1 5 2 5 and the smog guy isn't sure if that is a 25 and 52 code or a 15 and 52 code etc.
It hesitates and surges slightly under acceleration until 4800 rpm at which time it runs properly until 5300 where i stop revving it.
it idles fine and never misses and runs smooth if you sit in it in neutral and rev it up
any way to determine exactly what codes are showing by this flashing sequence?
it has 31" tires and is pathetically sow to accelerate . is this normal?
any ideas what the prob might be?
any way to test a throttle body to determine if it is not working properly?
thanks in advance for any help
Not to seem gheyto, but if you are neat and clean with some black silicon sealant you can repair that seal and it would be really hard to tell.
You could also do what I'm about to do to mine and delete the whole sunroof. I'm about to weld a patch panel where my sunroof was because I'm tired of it leaking. The glass is also cracked and glass frame is bent too.
It's an extreme solution for my case, my T4R sunroof doesn't leak, and if it does, I'll need to find a solution because my wife likes it :)
