jwkilgore
I have a 2011 SR5. I bought it for the purpose of taking it hunting, back-country camping, and other off-road uses. But it became my wife's daily driver for various reasons, and for the past several years off-road driving hasn't been in the cards. Only occasional muddy dirt roads and a few snow storms.
It's 100% stock, and it has the OEM running boards that hang down a few inches below the already-low SR5 trim.
Now I've found a better hunting spot, but I need more clearance to get there. The running boards keep hanging on ledges and boulders.
I don't have a huge amount of money to sink into this, but almost anything would be cheaper than bodywork to repair dented rocker panels or replacing ripped-off running boards.
What would the experts suggest as beginner-level mods to get a few more inches?
A basic suspension lift is a no-brainer. I'm planning on a 2.5/1.5 Daystar lift/leveler.
I considered bigger tires, but after much research I decided that the extra gas expense would kill me. My wife doesn't drive overly fast, but she leaves red lights as if she's on a drag strip.
Next up would be replacing the running boards with rock slides. Almost all require removing the SR5 rocker trim, which would cause much anguish with my wife. Supersliders from Rocky-Road have a set that fit under my current trim, but as near as I can tell they would hang almost as low as my current running boards. The advantage would be fewer mods (bolt-on, no trim cutting); the disadvantage would be no additional ground clearance. HOWEVER, if I hit I'll hit on steel rails instead of aluminum fins.
Is this a good plan? Will the lower Supersliders plus a lift give me what I want, or should I bite the bullet and cut the trim?
Edit:
Just added a pic of my stock ride as my avatar. I have to take her out and get her muddy every once in a while so she doesn't get too depressed.
Edit:
