Fixing the transfer case shift motor leak from within..
MandAtaco
Member
Well, I put it off long enough but the drips have been getting bigger and bigger, and now my driveway is a mess! On mine, it wasn’t the shaft seals that were leaking, but the large O-ring from the shift motor to the transfer case or T-case.
Finally decided to bite the bullet on this and get the leaking t-case shift motor fixed. I looked at all the threads of guys pulling the shift motor itself apart to avoid pulling and splitting the t-case, but honestly the thought of screwing around with all those little pieces, lying on my back under the truck, didn’t seem inviting at all. On top of that, I was afraid to not get the thing in “time” and having to replace the shift motor itself. For me, pulling the case and going from the inside was the way to go.
The following write up is an abbreviated version (and some of my own tips) of what the FSM says to do for a T-case tear down. I used it as a reference, but noticed that a lot of the steps in the FSM don’t apply. It shows you how to do a complete tear down, and we only need to get in far enough to remove the shift motor. I recommend 100% having a copy of the FSM to reference for pictures, torque specs, etc.
You’re going to need parts and some RTV to do the job. The large o-ring you can get from Toyota, the part number is 90301-56009 and it cost me a little under $8.00. The other 2 seals you will need are from Colonial Seal, they can’t be purchased through Toyota unless you buy the entire shift motor, ranging around the $1000 mark. The part description is “AS 15x23x7 NBR – Oil seal” and they were about $3.45 a piece when I purchased them. I ordered 5 of them just to have some spares. Check out this thread here… HERE and special thanks to “geurillawarfare” for posting up where to acquire these seals from.
I used Ultra Black RTV to reassemble the case. The only specialty tool I needed was a 3 jaw puller, a two would work also. Everything else was basic hand tools.
Pulling the transfer case was actually really easy; it literally took me 45 minutes to get it out once I had the runner up on jack stands. I used the FSM as a reference, but don’t follow it verbatim! It says you have to remove the transmission and the transfer case to pull the t-case; you DO NOT have to do this!
• Remove the rear drive shaft completely so you’re not trying to work around it.
• Just unhook the front driveshaft from the transfer case and let it hang out on the cross member.
• Drain the fluid from the T-case
• Unhook the breather line from up on top of the T-case and let it hang
• Unhook the electrical connector from the shift motor
• There are two brackets that hold the electrical harness for the t-case, one is held on by a t-case to trans bolt, and one is held on by a t-case bolt. I just pulled both these bolts and let the harness hang down by the transmission. The bolts had to be removed anyway.
• If you have a transmission jack, nows the time to put it under the transfer case, I didn’t, so I used a floor jack to hold the weight of the case. Remove the 8, 12mm bolts that hold the t-case to the transmission. Rock it back and forth a little bit and it should slide right out of tail end of the transmission. Be careful not to tear up the seal on the tail of the trans. An extra pair of hands would be helpful here; I had my wife run the jack while I steadied the transfer case down to the floor.
My workbench wasn’t really big enough to work on the t-case, so I did all the work on the floor on an old piece of cardboard to try to keep the mess to a minimum. The case comes apart pretty easily.
• Remove the front driveshaft drive flange nut. I just used my Ryobi impact and it took it right off.
• Use a 2 or 3 jaw puller to remove the drive flange.
• Remove 4, 12mm bolts and the factory “skid plate”.
• Remove the 12, 12mm bolts around the parameter of the T-case
• Now pry the two case halves apart to break the factory seal. I found a place to start it where I could pry without prying on the sealing surface. NOTE: Take special care not to nick the sealing surface!
• Separate the two halves. Note: the only loose pieces that may fall out when you separate the case, is the input shaft needle bearing, no big deal, I’ll show you where it goes later.
• Take the front case half and sit it upside down on something to let all of the oil drain out of it, this will help you greatly later when you go to reassemble the case halves!
Now that you have the halves separated you can get into the case to remove the shift motor.
• Remove the 3 c-clips from the shift rails.
• Remove the 2, 12mm bolts from the shift forks
• Slide the shift forks and the corresponding shift assembly off the shafts and gears. Note: not sure if it matters, but I marked the gear drums when I pulled them off to make sure they went back together the same way.
• The last step is to pull the 3, 12mm bolts that hold the shift motor to the t-case and remove the shift motor. I had to wiggle the shaft a little bit to get it out of the case, shouldn’t take too much though.
Once you have the shift motor out, you can replace the o-ring and 2 shaft seals.
• Remove the single phillips screw on the top of the front of the shift motor where the 2 shift rods come out.
• Remove the old O-ring
• I used 2 sharp picks to pry up the two shaft seals, one to pry with and one to spread the load out, don’t pry against the plastic shift housing or you WILL dent it!
• There are a couple of detents on the shift shafts, wrap them in electrical tape, put some oil on the inside of the new seals, and slide them on being careful not to tear the new seal on the edges. (Electrical tape) should help with this. I was able to push the shaft seals into the shift motor housing most of the way. Then use a long pipe or a dull punch and work your way around the seal to finish seating it. Work slowly here so you don’t tear up the new seals.
• Install your new O-ring (I dipped it in oil first to help it slide into the T-case)
• Reinstall the plastic cover with the Philips screw.
Ready to go back in…
Here’s a look of the old shaft seals vs. the new. The new ones definitely looked a lot better. Also is a picture of the new vs. old outer o-ring, a huge difference between the two. The old one was flat and dried out.
Now you’re ready to reinstall everything, and installation really is reverse of removal!
• Reinstall the shift motor and 3, 12MM bolts. Make sure the o-ring slides into the housing easily.
• Reinstall the shift forks, gears, and the 3 c-clips.
• Sit the rear case upright for reassembly; I sat the rear drive flange on a 2x4 and the shift motor on the ground, puts the case in a nice level position to work with.
Before you put the cases back together you have to make sure the two mating surfaces are clean of all old RTV. I scrapped it with a razor blade and then wire brushed everything, taking special care not to get any of the old material down in the cases. Finally, wipe both sides with some brake clean or some type of non-residue cleaner. Note: The last thing you need to be sure of before you reassemble the T-case, is that your input shaft needle bearings and spacer are sitting on the input shaft.
If the needle bearing didn’t fall out during disassembly, it could still be here in the case front:
• Then use RTV per RTV’s instructions and slide the case halves back together, listening to make sure you don’t knock the needle bearings off the input shaft. You’ll hear it fall if you do.
• Reinstall your 12, 12mm bolts and torque to spec.
• Reinstall your front drive flange, nut, and torque to spec. Re-stake the front flange nut.
No special tricks here, you’re ready to reinstall into the truck, add oil, and clean your driveway!
The entire job shouldn’t take more than 4 or 5 hours. Most of my time was spent cleaning up the case halves before reassembly, and letting the RTV cure some before I started handling it. I used less than 2 quarts of Mobil 1 full synthetic 75W-90 to refill.
Like I said at the beginning, have your FSM handy and reference it for most of the intermediate step pictures. Hope this helps someone else and gives you an idea of how to fix this problem without tearing the shift motor apart.
“MandAtaco”
Wow, nice write-up.
Not sure if I would ever tackle this myself (currently knocking on wood), but it's nice to have this reference.
Thanks for taking the time to write this up with pictures.
I am book marking in case I ever need to replace my actuator.
Had read that replacing the actuator was a 2000$ job, but I would feel good doing it myself after seeing these pics.
Dave
Thanks guys. I did a lot of research on fixing the leak, but never could find any info from someone who actually split the case to repair it. Hopefully this just gives other people doing research at least a better idea of what's needed and involved to make an intelligent decision to repair theirs.
Mike
Very nice writeup!
This should be a sticky for people to use.
Also this procedure can be used to change the entire actuator also.
Good work, thanks!
kudos!
Very nice writeup!
Good work, thanks!
This is GREAT thread! But, I never saw where he actually took the actuator off. That's key. Reinstalling it is VITAL (has to be perfectly synched) Even if he did, Toyota doesn't sell the actuator itself. But I do remember a thread where a member "serviced" and replaced the actuator motor (part number and all by a third party company), but never reported back when it came time to reinstalling it.
So, the "unicorn" repair procedure is still out there.........................
Excellent article! I was wondering if it is possible to leave the transfer case (TC) in place and just split/remove the rear half of the case only? That might save some time and heavy lifting.
are you saying they wont sell that part?
because I had one installed prior to purchasing my 06. the work was performed at a dealership, with what I ASSumed to be OEM parts.
or did you mean they don't sell the actuator motor by itself?
That is what I understand, I could wrong. I got that info by the MANY threads regarding this issue. If one can get the actuator (expensive) from Toyota, great, but the missing link is properly installing it. Apparently no one knows how.
I was able to find an actuator online, I would assume the dealership should be able to order the component as well. Most likely many do not want to do this because of the labor involved and would rather sell the owner a new transfer case instead.
ACTUATOR ASSY, TRANSFER SHIFT. TRANSFER LEVER & SHIFT ROD made by Toyota. #3641035093
As for installing the Actuator, there is no secret to installing it in terms of timing or what not if you're doing it the correct way. The correct way per Toyota is just as the OP did: split the case, unpin/unbolt the rods, remove the actuator, and reverse the process as per the FSM. The issue in timing comes from people trying to not perform the correct factory procedure, the actuators were never meant to be serviced and Toyota provides no real information on how to re-time the unit if you try and gut the internals. Now some very crafty people have managed to do just that, but their units seem to still be a bit off on timing; so until someone figures out a way to properly re-time the units and do it consistently, I can't in good conscious recommend that method (though it really is a good trick once someone figures out that one little kink.)
But as far as the OP is concerned, he pretty much did exactly what the FSM details. :)
Funny you mention that, you could in theory do this, I was thinking about the same thing. I honestly think though, you wound spend more time doing this procedure under the truck, than just pulling it completely. The reason being, is that its only 8 bolts to remove the case completely, maybe 10 min worth of work. I really feel like you'd spend more time than that crawling in and out. You would also have to pull the front drive shaft completely to get to the front output flange, and add to that, you have 90W dripping in your face the entire time :rain:!
This..... You can buy the shift actuator from the dealer, what you cannot buy from Toyota, is the little actuator seals, they are part of the actuator you get from Toyota. That's why they have to be purchased from a third party, (Colonial Seal).
The ONLY time you have to worry about timing anything, is if you disassemble the actuator motor itself. If you remove the actuator the way your "supposed" too, then you don't have to ever worry about timing anything. Same goes for a newly purchased one from Toyota, remove the old, install the new, the part is "timed" from the factory.
Mike
V8 transfer case thread A+, what about V6 models?
I was able to find an actuator online,.....
As for installing the Actuator, there is no secret to installing it in terms of timing or what not if you're doing it the correct way. The correct way per Toyota is just as the OP did:.... But as far as the OP is concerned, he pretty much did exactly what the FSM details. :)
OK, makes complete sense, thanks for clearing that up. :thumb:
Mike
Again, thanks for this thread. I would rate this thread as the BEST THREAD TO REPAIR our transfer cases.
Now to the stupid question: This thread is for the transfer case of a V8. Is the V6 transfer case similar (enough) that this info would be pertinent?
The only real difference between the 2UZ-FE and 1GR-FE equipped transfer cases is that the shift rod on the 1GR-FE units has a spot for another shift fork and there is a syncro for 2WD. The instructions would still apply with the addition of removing an additional shift fork.
OK, so this thread is still (confirmed) pertinent for us V6 guys. Cool.
Just an update, about 1000 miles later and she's all dry. If anything negative happens down the road, I'll pass it along. Thanks again for all your responses.
Just saw this write-up and it is outstanding. I will be doing this repair over the Christmas/New Years break so this couldn't have come at a better time for me.
Thanks MandAtaco for doing this. Still no leak? and actuator still working ok?
Very nice write up. This topic has come up quite a few times. This thread should be considered for a sticky since it's actually often brought up.. Something to consider mods :)
CoaterZ_FL
