FJ coil spring ?
Gstick
Member
Will installing FJ Cruiser coil springs on my stock 10' 4R SR5 4x4 lift my ride up at all ? I am looking to get 2" (MAXIMUM) lift front and rear, keeping the stock rake. Correct me if I'm wrong, but if I add 2 adjustable Billies to the front, and 2 non-adj to the rear with the FJ springs, this may be accomplished ?
Whether or not the FJ springs make your 4R ride higher is unclear.
What is clear is that they're not the same spring. Given that a FJ has a lower GVWR but within 100 lbs of curb (empty) weight, one would surmise the springs are not rated to the same weight, and may actually make it ride lower.
If you do install them, get back to us.
The other option is Bilstein 5100's up front and spacer blocks in the rear. That's probably cheaper too.
I don't think that will work. I have been e-mailing Camburg about their FJ front coilovers and UCA as well as rear springs and shocks. This is what they have told me:
Me
I am trying to put together a lift for my 2010 Toyota 4 runner trail edition (with KDSS) and I was looking at Part# CAM-310036. I was wondering if this uniball upper control arm would work on my 4runner.
Will the whole kit (front coilovers, rear springs/shocks) for the FJ interchange with the 2010 4runner Trail (with KDSS)?
Any infor you can provide would be greatly appreciated.
CAM
Yes those arms will work fine. Sorry for the delay getting back to you, we had some email/network problems.
No the rear suspension is different on the 4-Runner compared to the FJ.
So I guess the fronts would be the same but not the rears, from what they told me.
Zett
