Floor board water
swim.bike.run
So....
Just finished hitting some trails and upon return and cleaning up the truck we noticed water in the right side floor board in the front and rear pax area. Nothing coming from the upper footwell. We hit a lot of water so I'm wondering if we went too deep or hit something water too hard. Is there anything else that could be clogged or a hole underneath the chassis? Not soaked but definitely moist.
Thoughts?
Have you checked your AC condensate drain tube?
It vould be disconnected under dash on pass. side or the end of the tube under truck could be plugged. Either can cause condensate water to spill into pass. footwell.
So....
Thoughts?
Could be the drain plug, see what [MENTION=138432]Liquidmantis[/MENTION] went through, I think in his thread he got water inside twice. Not sure if you were as deep as him.
http://www.toyota-4runner.org/5th-gen-t4rs/217163-liquidmantiss-modest-[boring]-build-thread-9.html
I’ll take a look first thing in the morning. Hopefully it’s sokething simple.
There are drain plugs under the carpet. However, it's probably unlikely that they seeped into from there. I would pull up the plastic lower panels by the lower door that hide the wire harness. You should be able to tell if water go in through there. If your carpet is wet, u might have to pull it all out. There is padding/insulation underneath the carpet that is impossible to dry without pulling out the carpet.
Do those lower door panels pop off easily?
Is this hole where the drain line comes from? Removed the door sills and saw the line. The dealer also blew out the ac/sunroof drain. After removing the sills covers and feeling around underneath the carpet the foam was not wet and the floor of the vehicle was dry. Also, I did not see any drain holes. What am I missing?
